[postgis-users] Split linestring into two line
Saurav Ranjit
ranjitsaurav at gmail.com
Thu Aug 8 01:26:47 PDT 2013
Hi Hugues,
Thanks for your reply.
This is what i am trying to do.[image: Inline image 1]
I have a single line string as shown in the figure above. I want to split
this line as shown in figure below.
[image: Inline image 2]
i need to split a single line into two line in postgis. I am not sure if
this can be done or not.
Hope you get my point.
Thanks again
Saurav
On Thu, Aug 8, 2013 at 2:55 PM, Hugues François
<hugues.francois at irstea.fr>wrote:
> Hello,
> It is hard to give you an answer if we don't know what exactly you are
> looking for and how you want to proceed (i.e. especially what are your
> input data)
> => if you want to extract specific substrings from your original ones, the
> answer of Nicola seems to be the good one
> => if you want to cut your linestring given another geometry, st_split may
> help you but we canno't tell you it will be the result you are looking for
> since we don't have more information about your data.
> Did you make some tests with these functions on a sample of your data ?
> Hugues.
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Saurav Ranjit
> *Sent:* Thursday, August 08, 2013 9:48 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* [postgis-users] Split linestring into two line
> hi
> i am new to the postgis. i would like to know if there is a way to split
> the linestring into two. what i am trying to get is: i have a map with
> single line, now i want to show that single line into two separate line
> parallel to each other.
> Line string looks like this.
> "LINESTRING(120.5523267 13.7257305,120.5522595 13.7265231,120.552205
> 13.7270875)"
> can ST_split function be used for this purpose? Is yes how it is done?
> Thanks in advance
> Regards
> Saurav Ranjit
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Saurav Ranjit
Master's Student in Engineering of Remote Sensing and Geographic
Information Systems (RSGIS)
School of Engineering and Technology (SET)
Asian Institute of Technology (AIT)
Thailand
Mobile: (+66) 800544946
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130808/e9f2db40/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130808/e9f2db40/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130808/e9f2db40/attachment-0001.png>
