[postgis-users] Problems installing on Linux
James David Smith
james.david.smith at gmail.com
Thu Aug 8 08:04:17 PDT 2013
On 8 August 2013 16:02, James David Smith <james.david.smith at gmail.com> wrote:
> On 8 August 2013 15:57, Wilkins, Brian <bwilkins at harris.com> wrote:
>> Do you have perl installed? It seems like it is unable to execute the perl script.
>> -----Original Message-----
>> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of James David Smith
>> Sent: Thursday, August 08, 2013 10:53 AM
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] Problems installing on Linux
>> On 8 August 2013 09:43, James David Smith <james.david.smith at gmail.com> wrote:
>>> On 6 August 2013 23:32, BladeOfLight16 <bladeoflight16 at gmail.com> wrote:
>>>> On Tue, Aug 6, 2013 at 12:53 PM, James David Smith
>>>>> However it says that Topology and Raster support are not present. So
>>>>> I thought that I could now run the following commands to install
>>>>> those
>>>>> too:
>>>>> <snip>
>>>>> psql:/usr/pgsql-9.0/share/contrib/postgis-2.0/rtpostgis.sql:48: ERROR:
>>>>> could not load library "/usr/pgsql-9.0/lib/rtpostgis-2.0.so":
>>>>> libgeos-3.2.0.so: cannot open shared object file: No such file or
>>>>> directory
>>>>> Any idea why there is still mention of libgeos-3.2.0 ? I thought
>>>>> I'd sorted that out now?
>>>> Could rtpostgis-2.0.so be a pg-routing binary? I noticed two of your
>>>> copies of GEOS are in subdirectories of /depot/shared/pgrouting/.
>>>> Maybe the routing binary is still linked to the old GEOS.
>>>> As for raster, did you install GDAL? I'm pretty sure that GDAL is
>>>> required for raster support.
>>>> Honestly, you have a lot of different pieces and versions installed,
>>>> and since you installed a bunch of them manually, cleaning them out
>>>> does not seem practical. Have you considered just installing on a
>>>> clean machine that's never had PostgreSQL? Or maybe even backing up
>>>> your data and then wiping this machine (assuming there even is data
>>>> to preserve)? Even if it costs a little bit to get a clean machine, I
>>>> bet it's less than the cost of your time (assuming you're on the job).
>>>> _______________________________________________
>>> Hi all,
>>> Just reporting back. Have made progress again. We had to clean and
>>> then re-make and install GDAL. If I'm honest I'm not quite sure why,
>>> but once we had done this everything seemed to work ok. :-)
>>> Thanks
>>> James
>> Hi there,
>> Not quite done I'm afraid. Sorry and thanks for your continued help.
>> I've now got a database in my cluster called 'james_traffic_restored'
>> which is a postgis2 database with topology and raster support enabled.
>> Great.
>> Before I started all this I dumped my old database using pg_dump.
>> pg_dump mydb > db.sql
>> I saved it as a SQL file and also as a dump file.
>> /home/james/james_traffic_08082013.dump
>> /home/james/james_traffic_08082013.sql
>> I now want to put this data back into my newly database called 'james_traffic_restored'. So I do this:
>> pg_restore -d james_traffic_restored james_traffic_08082013.dump
>> However I get lots of errors. I've not bothered providing them, as I think that this is wrong anyway. I think I need to do something like this instead:
>> sh /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis_restore.pl
>> /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis.sql
>> james_traffic_restored james_traffic_08082013.dump >
>> restore.log
>> But I get the following errors:
>> /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis_restore.pl: line 31:
>> use: command not found
>> /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis_restore.pl: line 32:
>> /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis_restore.pl: line 34:
>> my: command not found
>> /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis_restore.pl: line 36:
>> /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis_restore.pl: line 37:
>> syntax error near unexpected token `newline'
>> `Usage: $me [-v] <dumpfile>'
>> I've had a look at the postgis_restore file around these lines, but I'm not sure what the problem is.
>> Thanks
>> James
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Hi Brian,
> Yes, I think I have Perl installed. If I do:
> instmodsh
> l
> It tells me...: Installed modules are: Perl
> James
Also if I run " perl -v " then I get:
" This is perl, v5.8.8 built for x86_64-linux-thread-multi "
