[postgis-users] Problems installing on Linux
James David Smith
james.david.smith at gmail.com
Thu Aug 8 08:31:28 PDT 2013
On 8 August 2013 16:13, Wilkins, Brian <bwilkins at harris.com> wrote:
> See here: http://stackoverflow.com/questions/2517106/why-do-i-get-use-command-not-found-when-i-run-my-perl-script
> Could be your shell.
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of James David Smith
> Sent: Thursday, August 08, 2013 11:04 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Problems installing on Linux
> On 8 August 2013 16:02, James David Smith <james.david.smith at gmail.com> wrote:
>> On 8 August 2013 15:57, Wilkins, Brian <bwilkins at harris.com> wrote:
> [snip]
>> James
> Also if I run " perl -v " then I get:
> " This is perl, v5.8.8 built for x86_64-linux-thread-multi "
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Great stuff Brian. I've no idea how you knew that. But putting 'perl'
at the start seems to get it started. Though another problem
unfortunately!
------------WHEN I RUN THE SCRIPT--------
perl /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis_restore.pl
/usr/pgsql-9.0/share/contrib/postgis-2.0/postgis.sql
james_traffic_restored james_traffic_05082013.sql > restore.log
---------THIS IS WHAT I GET ----------------
Converting /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis.sql to
ASCII on stdout...
Reading list of functions to ignore...
Writing manifest of things to read from dump file...
: Cannot open manifest file
'/usr/pgsql-9.0/share/contrib/postgis-2.0/postgis.sql.lst'
