[postgis-users] Problems installing on Linux
Wilkins, Brian bwilkins at harris.com
Thu Aug 8 09:53:50 PDT 2013
Hmm, sorry you are having such a hard time. You could try pg_dump -Ft which will do it in a tar format, but -Fc is the most flexible format and I wrote detailed notes on the upgrade that I tested on two other systems here, so the procedures are sound. I am not sure why you are having issues there... I don't know why I said to do -d because you are right, it's not a valid option.
-----Original Message-----
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of James David Smith
Sent: Thursday, August 08, 2013 12:43 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Problems installing on Linux
On 8 August 2013 17:27, Wilkins, Brian <bwilkins at harris.com> wrote:
> I don't know how you created your dump, but this is how I created my dump about a month ago and got it to work:
> First,
> $ pg_dumpall -h localhost -p 5432 -U postgres -globals-only >
> globals.sql
> $ pg_dump -d -Fc <database-name> > /tmp/<dump name>.dmp
> I always dump the globals just in case...
> Brian
> David Smith
> Sent: Thursday, August 08, 2013 12:23 PM
> On 8 August 2013 16:43, Wilkins, Brian <bwilkins at harris.com> wrote:
>> postgis.sql.lst is the manifest file used to read in the sql functions, tables, etc. It is the original SQL plus .lst concatenated onto the filename.
>> Make sure /usr/pgsql-9.0/share/contrib/postgis-2.0/ has permissions
>> set to 755. For example, chmod 755
>> Or you can copy the script to like /tmp along with your sql and make sure your user can write to /tmp.
>> David Smith
>> Sent: Thursday, August 08, 2013 11:31 AM
>> On 8 August 2013 16:13, Wilkins, Brian <bwilkins at harris.com> wrote:
>>> See here:
>>> http://stackoverflow.com/questions/2517106/why-do-i-get-use-command-
>>> n
>>> o
>>> t-found-when-i-run-my-perl-script
>>> Could be your shell.
>>> David Smith
>>> Sent: Thursday, August 08, 2013 11:04 AM
>>> On 8 August 2013 16:02, James David Smith <james.david.smith at gmail.com> wrote:
>>>> On 8 August 2013 15:57, Wilkins, Brian <bwilkins at harris.com> wrote:
>>> [snip]
>>>> James
>>> Also if I run "  perl -v  "   then I get:
>>>  "  This is perl, v5.8.8 built for x86_64-linux-thread-multi  "
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> Great stuff Brian. I've no idea how you knew that. But putting 'perl'
>> at the start seems to get it started. Though another problem unfortunately!
>> ------------WHEN I RUN THE SCRIPT-------- perl
>> /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis_restore.pl
>> /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis.sql
>> james_traffic_restored james_traffic_05082013.sql > restore.log
>> ---------THIS IS WHAT I GET ---------------- Converting /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis.sql to ASCII on stdout...
>>   Reading list of functions to ignore...
>>   Writing manifest of things to read from dump file...
>> :    Cannot open manifest file
>> '/usr/pgsql-9.0/share/contrib/postgis-2.0/postgis.sql.lst'
> I've made a tmp folder in my home directory.
> /home/james/temp
> It now has the following in it:
> postgis_upgrade_20_minor.sql
> topology.sql
> legacy_gist.sql
> raster_comments.sql
> topology_upgrade_20_minor.sql
> legacy_minimal.sql
> restore.log
> uninstall_legacy.sql
> legacy.sql
> rtpostgis_legacy.sql
> uninstall_postgis.sql
> postgis_comments.sql
> rtpostgis.sql
> uninstall_rtpostgis.sql
> postgis_restore.pl
> rtpostgis_upgrade_20_minor.sql
> uninstall_topology.sql
> postgis.sql
> spatial_ref_sys.sql
> postgis.sql.lst
> topology_comments.sql
> I run the following:
> perl temp/postgis-2.0/postgis_restore.pl temp/postgis-2.0/postgis.sql
> james_traffic_restored traffic_backup_08082013.sql > restore.log
> But still get error:
> Converting postgis.sql to ASCII on stdout...
> pg_restore: [archiver] input file does not appear to be a valid
> archive
> postgis_restore.pl: pg_restore returned an error
> It sounds like it doesn't like the file type. So I did a new dump like so:
> pg_dump --verbose -F t --file traffic_backup_08082013_v3.sql
> james_traffic_backup
> I thought that this would make a TAR file which is what it seems to want. So I now do pg_restore again:
> james_traffic_restored traffic_backup_08082013_v3.sql > restore.log
> However I still get the same error:
> archive
> Aaaargh. What an earth file format does it want it to be? Or maybe this error is misleading?
> Thanks
> James
Did you mean to put '-d' in that dump command Brian? It says invalid and isn't on the command list?  I removed it and did:
pg_dumpall -U james --globals-only > globals.sql
pg_dump -Fc james_traffic_backup > temp/postgis-2.0/traffic_dump.dmp
It creates the files ok.
Then:
Converting temp/postgis-2.0/postgis.sql to ASCII on stdout...
pg_restore: [archiver] input file does not appear to be a valid archive
temp/postgis-2.0/postgis_restore.pl: pg_restore returned an error
Weird. I've been googling this too obviously and a few people have had the same issue. They tend to resolve it by dumping as a tar or similar, but I think I'm doing that. I've certainly tried too.
Can't thank you enough for your help.
James
