[postgis-users] [SOLVED] Re: [?] Creating a polygon from a group of polygons
Max Pyziur
pyz at brama.com
Mon Aug 12 02:51:52 PDT 2013
On Mon, 12 Aug 2013, Peter wrote:
> Well thats an easy one.
> If they *exactly* join,
> http://postgis.refractions.net/documentation/manual-1.4/ST_Union.html
> if they are a bit squishy, then one simple way is to:
> - st_buffer the multiple polygons all individually outwards by say 10km,
> - st_union them into a single polygon
> - st_buffer that one polygon inwards (negative) 10km
> Hopefully helpful contribution from one noob to another.
Much thanks.
I'm an occasional PostGIS user; two weeks of intense usage followed by
several months of forgetting. And then becoming impatient in trying to
find a solution once already used.
You're correct that the ST_Union function is key.
Minutes after sending my request I was able to cobble the following code
to get my results (the TEMP TABLE is only for one US region):
DROP TABLE padd_tmp;
CREATE TEMP TABLE padd_tmp (
ctry_code text,
market_region1 text,
market_region2 text,
prv_code text
COPY padd_tmp FROM stdin WITH NULL AS '';
US PADD1 PADD1 FL
US PADD1 PADD1 GA
US PADD1 PADD1 SC
US PADD1 PADD1 NC
US PADD1 PADD1 VA
US PADD1 PADD1 WV
US PADD1 PADD1 PA
US PADD1 PADD1 NY
US PADD1 PADD1 MD
US PADD1 PADD1 DE
US PADD1 PADD1 NJ
US PADD1 PADD1 CT
US PADD1 PADD1 RI
US PADD1 PADD1 MA
US PADD1 PADD1 NH
US PADD1 PADD1 VT
US PADD1 PADD1 ME
-- ST_Multi(ST_Union(ST_Transform(somegeom,4326))) is key here; ST_Multi
-- took me all the way home
SELECT bb.market_region2, st_multi(st_union(st_transform(aa.geom,4326)))
AS geom
INTO TEMP aa_zz
FROM us_states aa, padd_tmp bb, provinces cc
WHERE aa.state_fips = cc.prv_code
AND bb.prv_code = cc.alt_prv_code
AND cc.ctry_code = 'US'
GROUP BY 1;
SELECT market_region2 FROM aa_zz ORDER BY 1;
UPDATE market_regions set geom =
(SELECT geom FROM aa_zz
WHERE aa_zz.market_region2 = market_regions.market_region2)
WHERE market_regions.market_region2 IN (SELECT market_region2 FROM aa_zz);
> P.
MP
> Max Pyziur wrote:
>> Greetings,
>> Could someone please recommend how to create a polygon from a set of
>> polygons?
>> Specifically, a group of states (say, a set of contiguous northeastern
>> United States) and from that form the polygon containing this region
>> Much thanks,
>> Max Pyziur
>> pyz at brama.com
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
