[postgis-users] error on copying geometries between geometry columns
Pietro Rossin pierigis at gmail.com
Mon Aug 12 04:19:50 PDT 2013
Hello
I'm trying to copy polygons from one column to another to reduce vertex
numbers
my columns are geom (geom geometry(MultiPolygonZ,3004))
and geom_simply (geom_simply geometry(MultiPolygonZ,3004))
With this query
UPDATE mytable
   SET geom_simply=ST_SimplifyPreserveTopology(geom, 100)
I get this error:
ERROR: Geometry type (Polygon) does not match column type (MultiPolygon)
SQL state: 22023
Also this query return error:
UPDATE mytable
   SET geom_simply=ST_SimplifyPreserveTopology(st_multi(geom), 100)
SQL state: 22023
Why?
I know there are few multipolygon in the geom column..
Thanks
Pietro
View this message in context: http://postgis.17.x6.nabble.com/error-on-copying-geometries-between-geometry-columns-tp5003977.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
