[postgis-users] error with global/pg_filenode.map
Tung Thanh con500thoi at yahoo.com
Wed Aug 14 12:37:02 PDT 2013
Dear List
I am installing software name geo-node, on the way of installation I have some errors with postgresql/postgis and psycopg2
I have also removed and re-install postgresql and python-psycopg2 many time but It doesn't work
the problem when  I installed by using command as bellow
$sydi add-apt-repository xxxx
$sudo apt-get update
$sudo apt-get install geonode
and the errors occurred:
  File "/var/lib/geonode/bin/django- admin.py", line 5, in <module>
    management.execute_from_ command_line()
  File "/var/lib/geonode/lib/python2. 6/site-packages/django/core/ management/__init__.py", line 443, in execute_from_command_line
    utility.execute()
  File "/var/lib/geonode/lib/python2. 6/site-packages/django/core/ management/__init__.py", line 382, in execute
    self.fetch_command(subcommand) .run_from_argv(self.argv)
  File "/var/lib/geonode/lib/python2. 6/site-packages/django/core/ management/base.py", line 196, in run_from_argv
    self.execute(*args, **options.__dict__)
  File "/var/lib/geonode/lib/python2. 6/site-packages/django/core/ management/base.py", line 232, in execute
    output = self.handle(*args, **options)
  File "/var/lib/geonode/lib/python2. 6/site-packages/django/core/ management/base.py", line 371, in handle
    return self.handle_noargs(**options)
  File "/var/lib/geonode/lib/python2. 6/site-packages/south/ management/commands/syncdb.py" , line 90, in handle_noargs
    syncdb.Command().execute(** options)
  File "/var/lib/geonode/lib/python2. 6/site-packages/django/core/ management/commands/syncdb.py" , line 57, in handle_noargs
    cursor = connection.cursor()
  File "/var/lib/geonode/lib/python2. 6/site-packages/django/db/ backends/__init__.py", line 308, in cursor
    cursor = util.CursorWrapper(self._ cursor(), self)
  File "/var/lib/geonode/lib/python2. 6/site-packages/django/db/ backends/postgresql_psycopg2/ base.py", line 177, in _cursor
    self.connection = Database.connect(**conn_ params)
  File "/usr/local/lib/python2.6/ dist-packages/psycopg2/__init_ _.py", line 179, in connect
    connection_factory=connection_ factory, async=async)
psycopg2.OperationalError: FATAL:  could not open relation mapping file "global/pg_filenode.map": No such file or directory
    utility.execute()
  File "/var/lib/geonode/lib/python2. 6/site-packages/django/core/ management/commands/loaddata. py", line 71, in handle
Site default disabled.
To activate the new configuration, you need to run:
  service apache2 reload
Considering dependency proxy for proxy_http:
Module proxy already enabled
Module proxy_http already enabled
Enabling site geonode.
 * Restarting web server apache2        ... waiting        [ OK ]
 * Stopping Tomcat servlet engine tomcat6        [ OK ]
 * Starting Tomcat servlet engine tomcat6        [ OK ]
 * Restarting web server apache2        ... waiting .
Any ideas to fix
Many thanks
@QT
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130814/050dc582/attachment.html>
