[postgis-users] Subdividing a polygon (rectangle) into equal segments (smaller rectangles)
BladeOfLight16
bladeoflight16 at gmail.com
Fri Aug 16 22:26:11 PDT 2013
On Wed, Aug 14, 2013 at 6:01 PM, René Fournier <m5 at renefournier.com> wrote:
> The reason is that each of the rectangles are actually subdivided into 12
> smaller, equal rectangles, numbered/lettered A-L. How would you go about
> doing this? It doesn't seem like something I can compute in the initial
> query to retrieve the containing rectangle… Any ideas?
Sounds to me like you have data your database isn't modeling. Any
particular reason you don't want to store the further divided rectangles?
Assuming you have a reason you don't want to,
width_bucket<http://www.postgresql.org/docs/9.2/static/functions-math.html>comes
to mind:
SELECT width_bucket(ST_X(point), ST_XMin(rect), ST_XMax(rect), 4) AS
horizontal_subrect
, width_bucket(ST_Y(point), ST_YMin(rect), ST_YMax(rect), 3) AS
vertical_subrect
FROM (SELECT ST_GeomFromText('POLYGON ((0 0,0 100,100 100,100 0,0 0))') AS
rect) r
, (SELECT ST_MakePoint(50,50) AS point) p;
gives
horizontal_subrect = 3, vertical_subrect = 2. You would need to be able to
coordinate that column and row number to a rectangle letter, of course.
Someone else might be able to expound on this a bit more about whether it's
a good idea, but if your data is always rectangles, maybe Box2D would be
better than geometry.
SELECT ST_MakeBox2D(ST_MakePoint(0,0), ST_MakePoint(10,10));
I'm not sure if that gives any performance gains, but I wouldn't be
surprised at all if it did.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130817/77120b60/attachment.html>
