[postgis-users] raster intersect with polygon resulting in false NULL value
Hailey Eckstrand
haileyeckstrand at gmail.com
Wed Aug 21 14:04:58 PDT 2013
Hi Pierre,
I just downloaded & installed this morning:
http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_summarystatsagg.sql
But here is the print out:
http://hastebin.com/tubelisoda.pas
Hailey
On Wed, Aug 21, 2013 at 1:45 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>wrote:
> Hailey,
> Could you post here the definition of ST_SummaryStatsAgg() you are using.
> I'm pretty sure I fixed this some time ago. I'd like to compare what you
> have with what I have.
> Pierre
> > -----Original Message-----
> > From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> > bounces at lists.osgeo.org] On Behalf Of Hailey Eckstrand
> > Sent: Wednesday, August 21, 2013 4:18 PM
> > To: PostGIS Users Discussion; dustymugs at gmail.com
> > Subject: Re: [postgis-users] raster intersect with polygon resulting in
> false
> > NULL value
> > It looks like you were right bborie..
> > WITH foo AS (
> > SELECT * FROM zben_allwshds WHERE bid = 61
> > SELECT
> > a.rid,
> > ST_SummaryStats(ST_Clip(a.rast,1, f.geom, true))
> > FROM aet_1 a
> > JOIN foo f
> > ON ST_Intersects(a.rast, f.geom);
> > NOTICE: The two rasters provided have no intersection. Returning no
> band
> > raster
> > CONTEXT: PL/pgSQL function "st_clip" line 39 at assignment
> > NOTICE: Could not find raster band of index 1 when setting pixel value.
> > Nodata value not set. Returning original raster
> > CONTEXT: PL/pgSQL function "st_clip" line 41 at assignment
> > NOTICE: Invalid band index (must use 1-based). Returning NULL
> > CONTEXT: SQL function "st_summarystats" statement 1
> > rid | st_summarystats
> > 122 | (79,237,3,0,3,3)
> > 146 |
> > (2 rows)
> > On Wed, Aug 21, 2013 at 1:05 PM, Bborie Park <dustymugs at gmail.com>
> > wrote:
> > Hailey,
> > Can you run a query such as the following and post the results? I
> > had to do a double-take for the ST_SummaryStatsAgg() function as I'm not
> > familiar with that function.
> > WITH foo AS (
> > SELECT
> > a.rid,
> > FROM aet_1 a
> > JOIN foo f
> > I'm suspecting that ST_SummaryStatsAgg() is having an issue where
> > one tile's summary stats has NULL values being combined with the
> > aggregate summary stats.
> > -bborie
> > On Wed, Aug 21, 2013 at 12:26 PM, Hailey Eckstrand
> > <haileyeckstrand at gmail.com> wrote:
> > Hello,
> > I am trying perform aggregate statistics on a raster vector
> > overlay with a polygon of 192 sub polys. Many of the resulting 192 mean
> > values are correct.. however, I am encountering that one vector overlay
> > mean is NULL which I know to be incorrect. The polygon and raster are in
> > the same projection and when I look at them in QGIS they are overlaid
> > correctly and I can see that the polygon is over top of ~30 raster cells
> that
> > are all the value 3 (it is not over top of any NA values). One thing
> that is sort
> > of fishy is that QGIS is reading the raster statistics and no data value
> > incorrectly (values included below) compared to the base ascii raster
> > gdalinfo which is included below.
> > My query:
> > select bid,(ST_SummaryStatsAgg(ST_Clip(rast,1, geom,
> > true))).mean
> > FROM aet_1,(select * from zben_allwshds where bid = 61)
> > foo
> > WHERE ST_Intersects(rast, geom)
> > GROUP BY bid
> > order by bid;
> > Returning no band raster
> > assignment
> > pixel value. Nodata value not set. Returning original raster
> > assignment
> > NULL
> > CONTEXT: PL/pgSQL function "raster_summarystatsstate"
> > line 9 at assignment
> > SQL function "raster_summarystatsstate" statement 1
> > bid | mean
> > 61 |
> > Query which returns all the Summary Stats (order of stats
> is
> > count | sum | mean | stddev | min | max)
> > true)))
> > foo
> > GROUP BY bid
> > order by bid;
> > assignment
> > assignment
> > NULL
> > bid | st_summarystatsagg
> > 61 | (,237,,,3,3)
> > The raster was loaded into postgresql with the raster2pgsql
> > tool:
> > raster2pgsql -s 3005 -I -C -M aet_1.asc -F -t 100x100
> > public.aet_1 | psql -d NWBC
> > gdalinfo of the loaded raster:
> > gdalinfo aet_1.asc
> > Driver: AAIGrid/Arc/Info ASCII Grid
> > Files: aet_1.asc
> > aet_1.asc.aux.xml
> > Size is 2331, 2895
> > Coordinate System is `'
> > Origin =
> > (173461.904000000009546,1929781.912000000011176)
> > Pixel Size = (400.000000000000000,-
> > 400.000000000000000)
> > Corner Coordinates:
> > Upper Left ( 173461.904, 1929781.912)
> > Lower Left ( 173461.904, 771781.912)
> > Upper Right ( 1105861.904, 1929781.912)
> > Lower Right ( 1105861.904, 771781.912)
> > Center ( 639661.904, 1350781.912)
> > Band 1 Block=2331x1 Type=Float32, ColorInterp=Undefined
> > Min=0.000 Max=9.000
> > Minimum=0.000, Maximum=9.000, Mean=1.955,
> > StdDev=2.375
> > NoData Value=-9999
> > Metadata:
> > STATISTICS_MAXIMUM=9
> > STATISTICS_MEAN=1.9546895049572
> > STATISTICS_MINIMUM=0
> > STATISTICS_STDDEV=2.3747620319231
> > Incorrect QGIS Raster Statistics:
> > STATISTICS_MAXIMUM=1.2341209168929e+033
> > STATISTICS_MEAN=5.9293249344197e+031
> > STATISTICS_MINIMUM=-9999
> > STATISTICS_STDDEV=2.4574481861697e+032
> > NODATA VALUE= -32768
> > PostGIS raster info:
> > rid serial NOT NULL,
> > rast raster,
> > filename text,
> > CONSTRAINT aet_1_pkey PRIMARY KEY (rid),
> > CONSTRAINT enforce_height_rast CHECK (st_height(rast) =
> > 100),
> > CONSTRAINT enforce_max_extent_rast CHECK
> > (st_coveredby(st_convexhull(rast),
> > '0103000020BD0B000001000000050000001D5A643BAF2C0541FCA9F1D2
> > EB7D27411D5A643BAF2C0541FED478E935723D41448B6CE7954B3141FE
> > D478E935723D41448B6CE7954B3141FCA9F1D2EB7D27411D5A643BAF2C
> > 0541FCA9F1D2EB7D2741'::geometry)),
> > CONSTRAINT enforce_nodata_values_rast CHECK
> > (_raster_constraint_nodata_values(rast)::numeric(16,10)[] = '{-
> > 9999}'::numeric(16,10)[]),
> > CONSTRAINT enforce_num_bands_rast CHECK
> > (st_numbands(rast) = 1),
> > CONSTRAINT enforce_out_db_rast CHECK
> > (_raster_constraint_out_db(rast) = '{f}'::boolean[]),
> > CONSTRAINT enforce_pixel_types_rast CHECK
> > (_raster_constraint_pixel_types(rast) = '{32BF}'::text[]),
> > CONSTRAINT enforce_same_alignment_rast CHECK
> > (st_samealignment(rast,
> > '0100000000000000000000794000000000000079C01D5A643BAF2C0541
> > FED478E935723D4100000000000000000000000000000000BD0B000001
> > 000100'::raster)),
> > CONSTRAINT enforce_scalex_rast CHECK
> > (st_scalex(rast)::numeric(16,10) = 400::numeric(16,10)),
> > CONSTRAINT enforce_scaley_rast CHECK
> > (st_scaley(rast)::numeric(16,10) = (-400)::numeric(16,10)),
> > CONSTRAINT enforce_srid_rast CHECK (st_srid(rast) =
> > 3005),
> > CONSTRAINT enforce_width_rast CHECK (st_width(rast) =
> > 100)
> > Install info:
> > PostgreSQL Version 9.1
> > postgis_full_version:
> > POSTGIS="2.0.1 r9979" GEOS="3.3.8-CAPI-1.7.8"
> > PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08"
> > LIBXML="2.7.8" TOPOLOGY RASTER
> > (1 row)
> > QGIS version:
> > 1.8.0-Lisboa
> > Compiled against GDAL/OGR
> > 1.9.2
> > Running against GDAL/OGR
> > 1.9.2
> > GEOS Version
> > 3.3.8
> > PostgreSQL Client Version
> > 8.3.10
> > Sorry for all the extra information, I just don't know what
> > people need to know to help. Thanks in advance!
> > Hailey
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-
> > users
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130821/e892f8eb/attachment.html>
