[postgis-users] raster intersect with polygon resulting in false NULL value
Hailey Eckstrand haileyeckstrand at gmail.com
Wed Aug 21 14:43:38 PDT 2013
Hi Pierre,
That did result in the correct response:
NWBC=# select bid,(ST_SummaryStatsAgg(ST_Clip(rast,1, geom, true)))
NWBC-# FROM aet_1,(select * from zben_allwshds where bid = 61) foo
NWBC-# WHERE ST_Intersects(rast, geom)
NWBC-# GROUP BY bid
NWBC-# order by bid;
NOTICE:  The two rasters provided have no intersection.  Returning no band
raster
CONTEXT:  PL/pgSQL function "st_clip" line 39 at assignment
NOTICE:  Could not find raster band of index 1 when setting pixel value.
Nodata value not set. Returning original raster
CONTEXT:  PL/pgSQL function "st_clip" line 41 at assignment
Did I have an old version of the function?
Thanks!
Hailey
On Wed, Aug 21, 2013 at 2:34 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>wrote:
> Heiley,
> What if you execute this and then retry your query:
> CREATE OR REPLACE FUNCTION raster_summarystatsstate(ss summarystats, rast
> raster, nband int DEFAULT 1, exclude_nodata_value boolean DEFAULT TRUE,
> sample_percent double precision DEFAULT 1)
>     RETURNS summarystats
>     AS $$
>     DECLARE
>         newstats summarystats;
>         ret summarystats;
>     BEGIN
>         IF rast IS NULL OR ST_HasNoBand(rast) OR ST_IsEmpty(rast) THEN
>             RETURN ss;
>         END IF;
>         newstats := _ST_SummaryStats(rast, nband, exclude_nodata_value,
> sample_percent);
>         IF $1 IS NULL THEN
>             ret := (newstats.count,
>                     newstats.sum,
>                     null,
>                     null,
>                     newstats.min,
>                     newstats.max)::summarystats;
>         ELSE
>             ret := (COALESCE(ss.count,0) + COALESCE(newstats.count, 0),
>                     COALESCE(ss.sum,0) + COALESCE(newstats.sum, 0),
>                     null,
>                     null,
>                     least(ss.min, newstats.min),
>                     greatest(ss.max, newstats.max))::summarystats;
>         END IF;
>         RETURN ret;
>     END;
>     LANGUAGE 'plpgsql';
> > -----Original Message-----
> > From: Hailey Eckstrand [mailto:haileyeckstrand at gmail.com]
> > Sent: Wednesday, August 21, 2013 5:05 PM
> > To: PostGIS Users Discussion
> > Cc: dustymugs at gmail.com; Pierre Racine
> > Subject: Re: [postgis-users] raster intersect with polygon resulting in
> false
> > NULL value
> > Hi Pierre,
> > I just downloaded & installed this morning:
> > http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_su
> > mmarystatsagg.sql
> > But here is the print out:
> > http://hastebin.com/tubelisoda.pas
> > Hailey
> > On Wed, Aug 21, 2013 at 1:45 PM, Pierre Racine
> > <Pierre.Racine at sbf.ulaval.ca> wrote:
> >       Hailey,
> >       Could you post here the definition of ST_SummaryStatsAgg() you
> > are using. I'm pretty sure I fixed this some time ago. I'd like to
> compare
> > what you have with what I have.
> >       Pierre
> >       > From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-
> > users-
> >       > bounces at lists.osgeo.org] On Behalf Of Hailey Eckstrand
> >       > Sent: Wednesday, August 21, 2013 4:18 PM
> >       > To: PostGIS Users Discussion; dustymugs at gmail.com
> resulting
> > in false
> >       > NULL value
> >       > It looks like you were right bborie..
> >       > WITH foo AS (
> >       > SELECT * FROM zben_allwshds WHERE bid = 61
> >       > SELECT
> >       > a.rid,
> >       > ST_SummaryStats(ST_Clip(a.rast,1, f.geom, true))
> >       > FROM aet_1 a
> >       > JOIN foo f
> >       > ON ST_Intersects(a.rast, f.geom);
> > Returning no band
> >       > raster
> > value.
> >       > NOTICE:  Invalid band index (must use 1-based). Returning NULL
> >       > CONTEXT:  SQL function "st_summarystats" statement 1
> >       >  rid | st_summarystats
> >       >  122 | (79,237,3,0,3,3)
> >       >  146 |
> >       > (2 rows)
> >       > On Wed, Aug 21, 2013 at 1:05 PM, Bborie Park
> > <dustymugs at gmail.com>
> >       > wrote:
> >       >       Hailey,
> >       >       Can you run a query such as the following and post the
> > results? I
> >       > had to do a double-take for the ST_SummaryStatsAgg() function
> > as I'm not
> >       > familiar with that function.
> >       >       WITH foo AS (
> >       >       SELECT
> >       >       a.rid,
> >       >       FROM aet_1 a
> >       >       JOIN foo f
> >       >       I'm suspecting that ST_SummaryStatsAgg() is having an issue
> > where
> >       > one tile's summary stats has NULL values being combined with
> > the
> >       > aggregate summary stats.
> >       >       -bborie
> >       >       On Wed, Aug 21, 2013 at 12:26 PM, Hailey Eckstrand
> >       > <haileyeckstrand at gmail.com> wrote:
> >       >               Hello,
> >       >               I am trying perform aggregate statistics on a
> raster vector
> >       > overlay with a polygon of 192 sub polys. Many of the resulting
> > 192 mean
> >       > values are correct.. however, I am encountering that one vector
> > overlay
> >       > mean is NULL which I know to be incorrect. The polygon and
> > raster are in
> >       > the same projection and when I look at them in QGIS they are
> > overlaid
> >       > correctly and I can see that the polygon is over top of ~30
> raster
> > cells that
> >       > are all the value 3 (it is not over top of any NA values). One
> thing
> > that is sort
> >       > of fishy is that QGIS is reading the raster statistics and no
> data
> > value
> >       > incorrectly (values included below) compared to the base ascii
> > raster
> >       > gdalinfo which is included below.
> >       >               My query:
> geom,
> >       > true))).mean
> = 61)
> >       > foo
> >       >               GROUP BY bid
> >       >               order by bid;
> intersection.
> >       > Returning no band raster
> >       > assignment
> > setting
> >       > pixel value. Nodata value not set. Returning original raster
> >       > assignment
> Returning
> >       > NULL
> > "raster_summarystatsstate"
> >       > line 9 at assignment
> >       >               SQL function "raster_summarystatsstate" statement 1
> >       >                bid | mean
> >       >                 61 |
> >       >               Query which returns all the Summary Stats (order
> of stats
> > is
> >       > count | sum | mean | stddev | min | max)
> geom,
> >       > true)))
> = 61)
> >       > foo
> >       >               GROUP BY bid
> >       >               order by bid;
> intersection.
> >       > assignment
> > setting
> >       > assignment
> Returning
> >       > NULL
> >       >                bid | st_summarystatsagg
> >       >                 61 | (,237,,,3,3)
> >       >               The raster was loaded into postgresql with the
> > raster2pgsql
> >       > tool:
> >       >               raster2pgsql -s 3005 -I -C -M aet_1.asc -F -t
> 100x100
> >       > public.aet_1 | psql -d NWBC
> >       >               gdalinfo of the loaded raster:
> >       >               gdalinfo aet_1.asc
> >       >               Driver: AAIGrid/Arc/Info ASCII Grid
> >       >               Files: aet_1.asc
> >       >                      aet_1.asc.aux.xml
> >       >               Size is 2331, 2895
> >       >               Coordinate System is `'
> >       >               Origin =
> >       > (173461.904000000009546,1929781.912000000011176)
> >       >               Pixel Size = (400.000000000000000,-
> >       > 400.000000000000000)
> >       >               Corner Coordinates:
> >       >               Upper Left  (  173461.904, 1929781.912)
> >       >               Lower Left  (  173461.904,  771781.912)
> >       >               Upper Right ( 1105861.904, 1929781.912)
> >       >               Lower Right ( 1105861.904,  771781.912)
> >       >               Center      (  639661.904, 1350781.912)
> >       >               Band 1 Block=2331x1 Type=Float32,
> > ColorInterp=Undefined
> >       >                 Min=0.000 Max=9.000
> >       >                 Minimum=0.000, Maximum=9.000, Mean=1.955,
> >       > StdDev=2.375
> >       >                 NoData Value=-9999
> >       >                 Metadata:
> >       >                   STATISTICS_MAXIMUM=9
> >       >                   STATISTICS_MEAN=1.9546895049572
> >       >                   STATISTICS_MINIMUM=0
> >       >                   STATISTICS_STDDEV=2.3747620319231
> >       >               Incorrect QGIS Raster Statistics:
> >       >               STATISTICS_MAXIMUM=1.2341209168929e+033
> >       >               STATISTICS_MEAN=5.9293249344197e+031
> >       >               STATISTICS_MINIMUM=-9999
> >       >               STATISTICS_STDDEV=2.4574481861697e+032
> >       >               NODATA VALUE= -32768
> >       >               PostGIS raster info:
> >       >                 rid serial NOT NULL,
> >       >                 rast raster,
> >       >                 filename text,
> >       >                 CONSTRAINT aet_1_pkey PRIMARY KEY (rid),
> >       >                 CONSTRAINT enforce_height_rast CHECK
> (st_height(rast)
> >       > 100),
> >       >                 CONSTRAINT enforce_max_extent_rast CHECK
> >       > (st_coveredby(st_convexhull(rast),
> > '0103000020BD0B000001000000050000001D5A643BAF2C0541FCA9F1D2
> > EB7D27411D5A643BAF2C0541FED478E935723D41448B6CE7954B3141FE
> > D478E935723D41448B6CE7954B3141FCA9F1D2EB7D27411D5A643BAF2C
> >       > 0541FCA9F1D2EB7D2741'::geometry)),
> >       >                 CONSTRAINT enforce_nodata_values_rast CHECK
> >       > (_raster_constraint_nodata_values(rast)::numeric(16,10)[] = '{-
> >       > 9999}'::numeric(16,10)[]),
> >       >                 CONSTRAINT enforce_num_bands_rast CHECK
> >       > (st_numbands(rast) = 1),
> >       >                 CONSTRAINT enforce_out_db_rast CHECK
> >       > (_raster_constraint_out_db(rast) = '{f}'::boolean[]),
> >       >                 CONSTRAINT enforce_pixel_types_rast CHECK
> >       > (_raster_constraint_pixel_types(rast) = '{32BF}'::text[]),
> >       >                 CONSTRAINT enforce_same_alignment_rast CHECK
> >       > (st_samealignment(rast,
> > '0100000000000000000000794000000000000079C01D5A643BAF2C0541
> > FED478E935723D4100000000000000000000000000000000BD0B000001
> >       > 000100'::raster)),
> >       >                 CONSTRAINT enforce_scalex_rast CHECK
> >       > (st_scalex(rast)::numeric(16,10) = 400::numeric(16,10)),
> >       >                 CONSTRAINT enforce_scaley_rast CHECK
> >       > (st_scaley(rast)::numeric(16,10) = (-400)::numeric(16,10)),
> >       >                 CONSTRAINT enforce_srid_rast CHECK
> (st_srid(rast) =
> >       > 3005),
> >       >                 CONSTRAINT enforce_width_rast CHECK
> (st_width(rast)
> >       > 100)
> >       >               Install info:
> >       >               PostgreSQL Version 9.1
> >       >               postgis_full_version:
> >       >                POSTGIS="2.0.1 r9979" GEOS="3.3.8-CAPI-1.7.8"
> >       > PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.9.2, released
> > 2012/10/08"
> >       > LIBXML="2.7.8" TOPOLOGY RASTER
> >       >               (1 row)
> >       >               QGIS version:
> >       >               1.8.0-Lisboa
> >       >               Compiled against GDAL/OGR
> >       >               1.9.2
> >       >               Running against GDAL/OGR
> >       >               1.9.2
> >       >               GEOS Version
> >       >               3.3.8
> >       >               PostgreSQL Client Version
> >       >               8.3.10
> >       >               Sorry for all the extra information, I just don't
> know what
> >       > people need to know to help. Thanks in advance!
> >       >               Hailey
> >       >       _______________________________________________
> >       >               postgis-users mailing list
> >       >               postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-
> >       > users
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130821/e4011885/attachment.html>
