[postgis-users] Speeding up geocoding on bigger states
Eric McKeeth
eldin00 at gmail.com
Thu Aug 29 00:36:48 PDT 2013
On Wed, Aug 28, 2013 at 10:54 PM, BladeOfLight16
<bladeoflight16 at gmail.com>wrote:
> On Wed, Aug 28, 2013 at 11:25 PM, Tom C <tom at tecrails.com> wrote:
>> I have set up the Tiger geocoder for all US states and territories, but
>> when I try to geocode addresses in larger states like CA and TX the
>> processing takes quite a long time. I have run SELECT
>> install_missing_indexes(); and VACUUM FULL; on the database and yet I was
>> able to write this email before I could geocode an address in TX. Any tips
>> or commands that I can run to speed things up?
> VACUUM FULL; will not collect statistics. Try VACUUM FULL ANALYZE;. If
> that doesn't help, try examining the EXPLAIN ANALYZE for trouble (bad
> estimates, not using indexes). You could provide the query and the EXPLAIN
> ANALYZE here if you can't find the problem.
Considering that VACUUM FULL has already been run, just ANALYZE will
probably get as good of results as VACUUM FULL ANALYZE, and should run more
quickly.
-Eric
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130829/394aaca2/attachment.html>
