[postgis-users] Query PLanning for spatial containment
Burgholzer, Robert (DEQ) Robert.Burgholzer at deq.virginia.gov
Fri Aug 30 03:00:48 PDT 2013
Dude, I am soooo dumb.  You're right, the query planner difference is in the WHERE.  And, yes, right again, I need to use the && to trigger the index, which works much more swiftly.
/r/b
From: postgis-users-bounces at lists.osgeo.org [postgis-users-bounces at lists.osgeo.org] on behalf of BladeOfLight16 [bladeoflight16 at gmail.com]
Sent: Thursday, August 29, 2013 10:08 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Query PLanning for spatial containment
On Thu, Aug 29, 2013 at 3:02 PM, Burgholzer, Robert (DEQ) <Robert.Burgholzer at deq.virginia.gov<mailto:Robert.Burgholzer at deq.virginia.gov>> wrote:
I just noticed something interesting, perhaps its trivial and well understood, but this is the first time I figured it out (older postgis and postgresql to boot).  I am doing a spatial containment query on two tables, table "a" being a point table in SRID 4326, with GIST index, and table "b" being a polygon with GIST index in SRID 26918, using the "transform" function to bring them into a common projection.  If I apply the transform to the polygon layer, the query planner (and indeed the query) is verrrry slow, whereas, if I apply the transform to the point layer, things go along much more swiftly.  Now I know, so I just thought I'd share, if anyone has any suggestions of course, I would be delighted to hear them.
Are you sure it's not the filter Filter: ((riverseg)::text = 'PS3_5100_5080'::text) that appears to only be present in the first query? I do notice that the estimate from the sc_cbp53 goes down from 1447 to 1 with the filter. EXPLAIN ANALYZE would give more information about what actually happened, and I wouldn't expect the query planner to behave the same in other versions of PostGIS. You might also benefit from a spatial index, and I believe in the older version, you need to do a bounding box check (&&) manually to trigger use of the index. (I can't recall which version, but one version of PostGIS built the && check into ST_Contains and many other functions.)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130830/058931d7/attachment.html>
