[postgis-users] service areas ( I want a polygon of the areas that only have one provider)
Nathaniel Clay
clay.nathaniel at gmail.com
Fri Aug 23 02:30:04 PDT 2013
Hi all,
I have a table of polygons that overlap with each other, I need the
polygon of the areas that only have one provider eg do not overlap.
Please find attached the shape file. Any help would be greatly appreciated!!
Thanks,
Nathaniel Hunter Clay
Type: application/x-dbf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130823/61b9fd00/attachment.bin>
PROJCS["NAD_1983_UTM_Zone_17N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-81],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
PROJCS["NAD83 / UTM zone 17N",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-81],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["EPSG","26917"]]
Type: application/x-esri-shape
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130823/61b9fd00/attachment-0001.bin>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130823/61b9fd00/attachment-0002.bin>
