[postgis-users] ST_intersects : error message
laurent
lcelati at latitude-geosystems.com
Mon Dec 2 07:45:16 PST 2013
Hello,
I have 2 tables : one points and one surface. I would like intersects the
geometries. I write the query but i have an error message :
CREATE TABLE example_intersections_a AS (SELECT ST_Intersection (part1.geom,
part2.geom)FROM fra_adm0 AS part_1,france_merge_pts1 AS part2 WHERE
ST_Intersects(part1.geom, part_2.geom));
ALTER TABLE example_intersections_a ADD COLUMN id SERIAL;
ALTER TABLE example_intersections_a ADD PRIMARY KEY (id);
Error message :
ERREUR: entrée manquante de la clause FROM pour la table « part1 »
LINE 1: ...ample_intersections_a AS (SELECT ST_Intersection (part1.geom...
********** Erreur **********
État SQL :42P01
Caractère : 66
COuld you tell me where is the error?
Thanks.
View this message in context: http://postgis.17.x6.nabble.com/ST-intersects-error-message-tp5005029.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
