[postgis-users] Create equally spaced lines within a polygon
Karl Zinglersen
karl.zinglersen at gmail.com
Tue Dec 3 10:04:37 PST 2013
Hi, I believe I was unclear - the centerlines have to straight. But I'll
keep in mind your reference to delauney triangles and skeletonization for
future purposes.
To create the centerline a manual sketch is probably OK. Could I then just
move on with linear referencing? Which function should I use - most seems
to be percentages of a linestring.
Karl
Den lørdag den 30. november 2013 13.21.46 UTC-3 skrev Nicolas Ribot:
> Hi,
> You should look at this french article for skeletonization of
> irregular polygons. The st_delaunayTriangles method can also help.
> Note that the middle line of a polygon is not always a straight line.
> Then, using linear referencing, it should be easy to walk the middle
> line to create perpendicular segments.
> Nicolas
> On 29 November 2013 18:25, Karl Zinglersen <karl.zi... at gmail.com<javascript:>>
> wrote:
> > I need to create transect lines across polygons for planning aerial
> surveys
> > for musk oxen and caribous in Greenland.
> > 1. In QGIS I have made polygons of the polygon zones for each survey.
> Each
> > polygon hold an attribute of spacing value, e.g. 5, 10 and 20 km.
> > 2. Lines must be equally spaced and parallel.
> > 3. Lines must be perpendicular to the polygon centerline.
> > 4. Centerline must run at the longest distance across the polygon - and
> > consequently the transects run as the shorter distances.
> > I've attached a hand made sketch, which display the concept.
> > I've tried this query
> > SELECT GENERATE_SERIES(FLOOR(ST_YMin(the_polygon))::int ,
> > CEILING(ST_YMax(the_polygon))::int,200) y_value, ST_XMin(the_polygon)
> x_min,
> > ST_XMax(the_polygon) x_max from
> > (SELECT the_geom AS the_polygon FROM lakes) l
> > SELECT ST_Intersection(the_geom, the_polygon) AS the_geom FROM
> > (SELECT the_polygon, ST_Setsrid(ST_MakeLine(ST_MakePoint(x_min,
> > y_value),ST_MakePoint(x_max, y_value) ), ST_Srid(the_polygon)) AS
> the_geom
> > FROM
> x_min,
> > )c
> > ) lines
> > from gis stackechange
> http://gis.stackexchange.com/questions/24064/filling-a-polygon-with-lines-using-postgis
> > however these transects runs horisontally and don't seem to take into
> > account the shape and rotation of the polygon centerline.
> > Should I be able to change the query or should take a different
> approach?
> > Karl Zinglersen
> > postgis-users mailing list
> > postgi... at lists.osgeo.org <javascript:>
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131203/6861cf7a/attachment-0001.html>
