[postgis-users] ST_MinkowskiSum
Stephen Mather
stephen at smathermather.com
Sat Dec 7 14:51:30 PST 2013
Hi All,
Digging SFCGAL... . Quick question-- is ST_MinkowskiSum a 2D calculation
of the Minkowski Sum when non-polyhedral surfaces are fed in? For example,
I tried this:
WITH pointt AS (
SELECT ST_MakePoint(0,0,0) AS the_geom
buffered AS (
SELECT ST_Buffer(the_geom, 30, 20) AS the_geom FROM pointt
rotatedOnItsSideX AS (
SELECT ST_RotateX(the_geom, 0.25 * pi()) AS the_geom from buffered
minkowski_sum AS (
SELECT ST_MinkowskiSum(x.the_geom, b.the_geom) AS the_geom FROM
rotatedOnItsSideX x, buffered b
SELECT 1 as gid, ST_AsText(the_geom) from minkowski_sum;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131207/29e9408c/attachment.html>
