[postgis-users] help with the Union of 2 shp
islanis at infomed.sld.cu
Thu Dec 12 06:02:32 PST 2013
> Hi,
> Try pg 21 of this:
> http://presentations.opengeo.org/2011_FOSS4G/postgis-power.pdf
> That will give you the metacode.
> Overlays. (he sighs.) Be glad you only have 2 layers... .
> Best,
> Steve
Hey steve thanks for the book is really good as a resume, but the only
apart that it have to do with my problem is the intersection of 2 shapes
"SELECT
a.*, b.*,
ST_Intersection(a.geom, b.geom)
FROM
a, b
WHERE
ST_Intersects(a.geom, b.geom);"
but my problem is different, i got as a mention 2 shapes with the
same projection and place,
and are the same but one is from one study, and the other is from
other stufy, but are the same
place and each one have data, the only things that they got different
are the size of the squares,the data they got and the
name of the columns are the same, but the values are different cause
the type of the study
,there is one that have the squares more smaller that the other, but i
dont want lose any data, i need that in the map it has seen like
the figure "A and B" but in the data each row got the values of A
and the values of B
1-the first shapefile
__________________
| 1 | shp=A
|_________________|
The one big country, this is a multipolygon shape
DATA=>dni01 numeric,dni02 numeric,dni03 numeric,
dni04 numeric,dni05 numeric,dni06 numeric,
dni07 numeric,dni08 numeric,dni09 numeric,
dni10 numeric,dni11 numeric,dni12 numeric,
dniann numeric,the_geom geometry
2-and the second shapefile
__________________
| 2 | 2 |
|________|________|
| 2 | 2 | shp=B
|________|________|
| 2 | 2 |
|________|________|
The same country, but this time in little pieces, the states, this
is a multipolygon shape too
and i want join the 2 shapes in only one shapefile getting something
like this
__________________
| 1,2 | 1,2 |
|________|________|
| 1,2 | 1,2 | shp=A and B
|________|________|
| 1,2 | 1,2 |
|________|________|
DATA=>dni01A numeric,dni02A numeric,dni03A numeric,dni04A numeric,
dni05A numeric,dni06A numeric,dni07A numeric,dni08A numeric,
dni09A numeric,dni10A numeric,dni11A numeric,dni12A numeric,
dniannA numeric,dni01B numeric,dni02B numeric,dni03B numeric,
dni04B numeric,dni05B numeric,dni06B numeric,dni07B numeric,
dni08B numeric,dni09B numeric,dni10B numeric,dni11B numeric,
dni12B numeric,dniannB numeric,the_geom geometry
i think that this is posible to do with postgis, but i dont know
why, am looking in quantumGIS but i lose data cause the big suare
overlap the little
ones and i lose data cause there is some places that i get NULL.
please help
thanks for all
>> On Mon, Dec 9, 2013 at 11:03 AM, J.Alejandro Martinez Linares
>> <islanis at infomed.sld.cu> wrote:
>> Hi People, i need your help, let say that i have 2 shapefiles
>> __________________
>> | 1 | shp=B
>> |_________________|
>> One big country, this is a multipolygon shape
>> __________________
>> | 2 | 2 |
>> |________|________|
>> | 2 | 2 | shp=B
>> |________|________|
>> | 2 | 2 |
>> |________|________|
>> this is a multipolygon shape too
>> something like this
>> __________________
>> | 1,2 | 1,2 |
>> |________|________|
>> |________|________|
>> | 1,2 | 1,2 |
>> |________|________|
>> i think that this is posible, please help me to get somthing
>> like this i need it.
>> Este mensaje le ha llegado mediante el servicio de correo
>> electronico que ofrece Infomed para respaldar el cumplimiento de
>> las misiones del Sistema Nacional de Salud. La persona que envia
>> este correo asume el compromiso de usar el servicio a tales fines y
>> cumplir con las regulaciones establecidas
>> Infomed: http://www.sld.cu/
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
