[postgis-users] help with the Union of 2 shp
Rémi Cura
remi.cura at gmail.com
Thu Dec 12 08:58:39 PST 2013
Sorry I'm not trying to offend you.
For example in this thread
https://groups.google.com/forum/#!topic/postgis-users/9pozIoUAZuI
The asker posted an image to explain better.
Cheers,
Rémi-C
2013/12/12 <islanis at infomed.sld.cu>
> no is not dificult to understand, what ever you want i'll give , just ask
> what do you want to a better understanding. please i need it
> "Rémi Cura" <remi.cura at gmail.com> escribió:
> I'm very sorry it is difficult to understand what you mean.
>> Maybe with a real drawing and link here to it, or to some screenshots?
>> Cheers,
>> Rémi-C
>> thanks for the quick answer Rémi, but, thats right thats one of answers,
>>> but my idea was not complete,because there is a
>>> 3rd shape, your answer works fine for the 1st and 2dn shapes, but not
>>> with
>>> the 3rd, because the 3rd has not suares inside,
>>> the 3rd shape have big triangles inside,the idea is that i need some
>>> routine that merge or blend the spatial data and with it the attributes
>>> of respective data, i need some ideas for do that, and am working on it,
>>> but not sucess, please i need help, thanks for all.
>>> 1-the first shapefile
>>> __________________
>>> | 1 | shp=A
>>> |_________________|
>>> num of poligons=1
>>> The one big country, this is a multipolygon shape
>>> DATA=>dni01 numeric,dni02 numeric,dni03 numeric,
>>> dni04 numeric,dni05 numeric,dni06 numeric,
>>> dni07 numeric,dni08 numeric,dni09 numeric,
>>> dni10 numeric,dni11 numeric,dni12 numeric,
>>> dniann numeric,the_geom geometry
>>> 2-and the second shapefile
>>> __________________
>>> | 2 | 2 |
>>> |________|________|
>>> | 2 | 2 | shp=B
>>> |________|________|
>>> | 2 | 2 |
>>> |________|________|
>>> num of poligons = 6
>>> The same country, but this time in little pieces, the states, this is a
>>> multipolygon shape too
>>> 3-and the second shapefile
>>> __________________
>>> | 3 / | shp=C
>>> | / 4 |
>>> |_____/___________|
>>> num of poligons = 2
>>> and i want join the 2 shapes in only one shapefile getting something
>>> like
>>> this
>>> ______________________________
>>> | |1,2,3 / |
>>> | 1,2,3 | /1,2,4 |
>>> |______________|____/_________|
>>> | |1,2/ | shp=A and B
>>> | |,3/ |
>>> | 1,2,3 | / 1,2,4 |
>>> |______________/______________|
>>> | 1,2,3 /1,| 1,2,4 |
>>> | /2,4| |
>>> |_________/____|______________|
>>> num of poligons = 9
>>> DATA=>dni01A numeric,dni02A numeric,dni03A numeric,dni04A numeric,
>>> dni05A numeric,dni06A numeric,dni07A numeric,dni08A numeric,
>>> dni09A numeric,dni10A numeric,dni11A numeric,dni12A numeric,
>>> dniannA numeric,dni01B numeric,dni02B numeric,dni03B numeric,
>>> dni04B numeric,dni05B numeric,dni06B numeric,dni07B numeric,
>>> dni08B numeric,dni09B numeric,dni10B numeric,dni11B numeric,
>>> dni12B numeric,dniannB numeric,dni01C numeric,dni02C numeric,
>>> dni03C numeric,dni04C numeric,dni05C numeric,dni06C numeric,
>>> dni07C numeric,dni08C numeric,dni09C numeric,dni10C numeric,
>>> dni11C numeric,dni12C numeric,dniannC numeric,the_geom geometry
>>> Seems like If you want :
>>>> for each little square, get the id of big square overlaping.
>>>> If this is simply this, you don't need the "intersection" function,
>>>> but only the "intersects" function :
>>>> You could do something like this
>>>> SELECT ss.id, bs.id , ss.geom
>>>> FROM smal_square_table AS ss, big_square_table AS bs
>>>> WHERE ST_Intersects(ss.geom,bs.geom)=TRUE
>>>> Cheers,
>>>> Rémi-C
>>>> Hi,
>>>>>> Try pg 21 of this: http://presentations.opengeo.
>>>>>> org/2011_FOSS4G/postgis-power.pdf
>>>>>> That will give you the metacode.
>>>>>> Overlays. (he sighs.) Be glad you only have 2 layers... .
>>>>>> Best,
>>>>>> Steve
>>>>>> Hey steve thanks for the book is really good as a resume, but the
>>>>>> only
>>>>> apart that it have to do with my problem is the intersection of 2
>>>>> shapes
>>>>> "SELECT
>>>>> a.*, b.*,
>>>>> ST_Intersection(a.geom, b.geom)
>>>>> FROM
>>>>> a, b
>>>>> WHERE
>>>>> ST_Intersects(a.geom, b.geom);"
>>>>> but my problem is different, i got as a mention 2 shapes with the same
>>>>> projection and place,
>>>>> and are the same but one is from one study, and the other is from other
>>>>> stufy, but are the same
>>>>> place and each one have data, the only things that they got different
>>>>> are
>>>>> the size of the squares,the data they got and the
>>>>> name of the columns are the same, but the values are different cause
>>>>> the
>>>>> type of the study
>>>>> ,there is one that have the squares more smaller that the other, but i
>>>>> dont want lose any data, i need that in the map it has seen like
>>>>> the figure "A and B" but in the data each row got the values of A and
>>>>> the
>>>>> values of B
>>>>> __________________
>>>>> | 1 | shp=A
>>>>> |_________________|
>>>>> __________________
>>>>> | 2 | 2 |
>>>>> |________|________|
>>>>> | 2 | 2 | shp=B
>>>>> |________|________|
>>>>> | 2 | 2 |
>>>>> |________|________|
>>>>> a
>>>>> like
>>>>> this
>>>>> __________________
>>>>> | 1,2 | 1,2 |
>>>>> |________|________|
>>>>> | 1,2 | 1,2 | shp=A and B
>>>>> |________|________|
>>>>> | 1,2 | 1,2 |
>>>>> |________|________|
>>>>> dni12B numeric,dniannB numeric,the_geom geometry
>>>>> i think that this is posible to do with postgis, but i dont know why,
>>>>> am
>>>>> looking in quantumGIS but i lose data cause the big suare overlap the
>>>>> little
>>>>> ones and i lose data cause there is some places that i get NULL.
>>>>> please help
>>>>> thanks for all
>>>>>> On Mon, Dec 9, 2013 at 11:03 AM, J.Alejandro Martinez Linares <
>>>>>> islanis at infomed.sld.cu> wrote:
>>>>>>> Hi People, i need your help, let say that i have 2 shapefiles
>>>>>>> __________________
>>>>>>> | 1 | shp=B
>>>>>>> |_________________|
>>>>>>> One big country, this is a multipolygon shape
>>>>>>> __________________
>>>>>>> | 2 | 2 |
>>>>>>> |________|________|
>>>>>>> | 2 | 2 | shp=B
>>>>>>> |________|________|
>>>>>>> | 2 | 2 |
>>>>>>> |________|________|
>>>>>>> is
>>>>>>> a multipolygon shape too
>>>>>>> something
>>>>>>> like this
>>>>>>> __________________
>>>>>>> | 1,2 | 1,2 |
>>>>>>> |________|________|
>>>>>>> |________|________|
>>>>>>> | 1,2 | 1,2 |
>>>>>>> |________|________|
>>>>>>> i think that this is posible, please help me to get somthing like
>>>>>>> this i need it.
>>>>>>> Este mensaje le ha llegado mediante el servicio de correo
>>>>>>> electronico
>>>>>>> que ofrece Infomed para respaldar el cumplimiento de las misiones del
>>>>>>> Sistema Nacional de Salud. La persona que envia este correo asume el
>>>>>>> compromiso de usar el servicio a tales fines y cumplir con las
>>>>>>> regulaciones
>>>>>>> establecidas
>>>>>>> Infomed: http://www.sld.cu/
>>>>>>> _______________________________________________
>>>>>>> postgis-users mailing list
>>>>>>> postgis-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>>> This message was sent using IMP, the Internet Messaging Program.
>>>>> Este mensaje le ha llegado mediante el servicio de correo electronico
>>>>> que
>>>>> Sistema
>>>>> Nacional de Salud. La persona que envia este correo asume el compromiso
>>>>> de
>>>>> usar el servicio a tales fines y cumplir con las regulaciones
>>>>> establecidas
>>> Este mensaje le ha llegado mediante el servicio de correo electronico que
>>> ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema
>>> de
>>> establecidas
> Nacional de Salud. La persona que envia este correo asume el compromiso de
> usar el servicio a tales fines y cumplir con las regulaciones establecidas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131212/045e90d2/attachment.html>
