[postgis-users] Export data from postgis db to OSM-like format?
Stephen Woodbridge woodbri at swoodbridge.com
Fri Dec 13 21:48:05 PST 2013
On 12/14/2013 12:32 AM, Maks Vasilev wrote:
> Hi!
> I'm use postgis base for mapnik rendering osm geo data and i have a
> parralel task to convert this data to other format.
> In database i have big update and conversion sql/pl_pgsql procedure to
> normalization raw osm data before to render it. And task chain
> osm->postgis->(normalization)->mapnik works fine.
> How to export geo data from my normalyzed postgis database to osm-liked
> data?
What do you plan to do with the data in this "osm-like" format?
If you want to load it into OSRM then look at there normalized ffile
format the osrm-extract generates.
-Steve W
