[postgis-users] help with the Union of 2 shp
Rémi Cura
remi.cura at gmail.com
Sat Dec 14 08:19:10 PST 2013
OK,
with luck you won't have precision issues.
(please note that the only good way to do this is to use postgis_topology
and faces.)
So here is one idea to do it :
table1 : first image, very big shape
table 2 : second image, smal rectangular shape
table 3 third image , mdium irregular shape
1.) convert poly from table 1 and table 3 to linestring. (i called these
lines dumped_lines for the following)
You can do it manually or use the function I wrote (beta)
https://github.com/Remi-C/PPPP_utilities/blob/master/postgis/rc_DumpLines.sql
2.) split poly from table 2 by the dumped_lines from table 1 (
http://postgis.net/docs/ST_Split.html) . The result are polygons
3.) Split the result from 2. by dumpl_lines from table 3. The result are
polygons.
3. is what you want geometrically. I'll call it splited_polygons for the
following
Now you want to get, for each splitted_polygons, the id of polygons of
table 1, and 3 which overlaps. You already have id from table 2 because you
can keep it during computing of 2. and 3.
you can do it sequentially :
SELECT DISTINCT ON (sp.geom) sp.geom, aray_agg(id) AS id_table1
FROM splited_polygons AS sp, table_1
WHERE ST_Overlaps(sp.geom, table_1.geom)=TRUE
, then the same type of query on result, with table 3
Cheers,
Rémi-C
2013/12/12 <islanis at infomed.sld.cu>
> I want to create little pieces of multipolygons from these 3 shapes (A,B
> and C)=result , result with all the sections formed with the intersection
> from the 3 shapes together, come on tell me , do you understand now what i
> want
> thanks
> no never mind am not offended, am trying that you understand Ok, here
>> are png of my 3 multipolygon shapes, what else do you need
>> "Rémi Cura" <remi.cura at gmail.com> escribió:
>> Sorry I'm not trying to offend you.
>>> For example in this thread
>>> https://groups.google.com/forum/#!topic/postgis-users/9pozIoUAZuI
>>> The asker posted an image to explain better.
>>> Cheers,
>>> Rémi-C
>>> no is not dificult to understand, what ever you want i'll give , just
>>>> ask
>>>> what do you want to a better understanding. please i need it
>>>> I'm very sorry it is difficult to understand what you mean.
>>>>> Maybe with a real drawing and link here to it, or to some screenshots?
>>>>> Cheers,
>>>>> Rémi-C
>>>>> thanks for the quick answer Rémi, but, thats right thats one of
>>>>> answers,
>>>>>> but my idea was not complete,because there is a
>>>>>> 3rd shape, your answer works fine for the 1st and 2dn shapes, but not
>>>>>> with
>>>>>> the 3rd, because the 3rd has not suares inside,
>>>>>> the 3rd shape have big triangles inside,the idea is that i need some
>>>>>> routine that merge or blend the spatial data and with it the
>>>>>> attributes
>>>>>> of respective data, i need some ideas for do that, and am working on
>>>>>> it,
>>>>>> but not sucess, please i need help, thanks for all.
>>>>>> 1-the first shapefile
>>>>>> __________________
>>>>>> | 1 | shp=A
>>>>>> |_________________|
>>>>>> num of poligons=1
>>>>>> The one big country, this is a multipolygon shape
>>>>>> DATA=>dni01 numeric,dni02 numeric,dni03 numeric,
>>>>>> dni04 numeric,dni05 numeric,dni06 numeric,
>>>>>> dni07 numeric,dni08 numeric,dni09 numeric,
>>>>>> dni10 numeric,dni11 numeric,dni12 numeric,
>>>>>> dniann numeric,the_geom geometry
>>>>>> 2-and the second shapefile
>>>>>> __________________
>>>>>> | 2 | 2 |
>>>>>> |________|________|
>>>>>> | 2 | 2 | shp=B
>>>>>> |________|________|
>>>>>> | 2 | 2 |
>>>>>> |________|________|
>>>>>> num of poligons = 6
>>>>>> The same country, but this time in little pieces, the states, this is
>>>>>> a
>>>>>> multipolygon shape too
>>>>>> 3-and the second shapefile
>>>>>> __________________
>>>>>> | 3 / | shp=C
>>>>>> | / 4 |
>>>>>> |_____/___________|
>>>>>> num of poligons = 2
>>>>>> a
>>>>>> and i want join the 2 shapes in only one shapefile getting something
>>>>>> like
>>>>>> this
>>>>>> ______________________________
>>>>>> | |1,2,3 / |
>>>>>> | 1,2,3 | /1,2,4 |
>>>>>> |______________|____/_________|
>>>>>> | |1,2/ | shp=A and B
>>>>>> | |,3/ |
>>>>>> | 1,2,3 | / 1,2,4 |
>>>>>> |______________/______________|
>>>>>> | 1,2,3 /1,| 1,2,4 |
>>>>>> | /2,4| |
>>>>>> |_________/____|______________|
>>>>>> num of poligons = 9
>>>>>> DATA=>dni01A numeric,dni02A numeric,dni03A numeric,dni04A numeric,
>>>>>> dni05A numeric,dni06A numeric,dni07A numeric,dni08A numeric,
>>>>>> dni09A numeric,dni10A numeric,dni11A numeric,dni12A numeric,
>>>>>> dniannA numeric,dni01B numeric,dni02B numeric,dni03B numeric,
>>>>>> dni04B numeric,dni05B numeric,dni06B numeric,dni07B numeric,
>>>>>> dni08B numeric,dni09B numeric,dni10B numeric,dni11B numeric,
>>>>>> dni12B numeric,dniannB numeric,dni01C numeric,dni02C numeric,
>>>>>> dni03C numeric,dni04C numeric,dni05C numeric,dni06C numeric,
>>>>>> dni07C numeric,dni08C numeric,dni09C numeric,dni10C numeric,
>>>>>> dni11C numeric,dni12C numeric,dniannC numeric,the_geom geometry
>>>>>> Seems like If you want :
>>>>>> for each little square, get the id of big square overlaping.
>>>>>>> If this is simply this, you don't need the "intersection" function,
>>>>>>> but only the "intersects" function :
>>>>>>> You could do something like this
>>>>>>> SELECT ss.id, bs.id , ss.geom
>>>>>>> FROM smal_square_table AS ss, big_square_table AS bs
>>>>>>> WHERE ST_Intersects(ss.geom,bs.geom)=TRUE
>>>>>>> Cheers,
>>>>>>> Rémi-C
>>>>>>> Hi,
>>>>>>>> Try pg 21 of this: http://presentations.opengeo.
>>>>>>>>> org/2011_FOSS4G/postgis-power.pdf
>>>>>>>>> That will give you the metacode.
>>>>>>>>> Overlays. (he sighs.) Be glad you only have 2 layers... .
>>>>>>>>> Best,
>>>>>>>>> Steve
>>>>>>>>> Hey steve thanks for the book is really good as a resume, but the
>>>>>>>>> only
>>>>>>>>> apart that it have to do with my problem is the intersection of 2
>>>>>>>> shapes
>>>>>>>> "SELECT
>>>>>>>> a.*, b.*,
>>>>>>>> ST_Intersection(a.geom, b.geom)
>>>>>>>> FROM
>>>>>>>> a, b
>>>>>>>> WHERE
>>>>>>>> ST_Intersects(a.geom, b.geom);"
>>>>>>>> but my problem is different, i got as a mention 2 shapes with the
>>>>>>>> same
>>>>>>>> projection and place,
>>>>>>>> and are the same but one is from one study, and the other is from
>>>>>>>> other
>>>>>>>> stufy, but are the same
>>>>>>>> place and each one have data, the only things that they got
>>>>>>>> different
>>>>>>>> are
>>>>>>>> the size of the squares,the data they got and the
>>>>>>>> name of the columns are the same, but the values are different cause
>>>>>>>> the
>>>>>>>> type of the study
>>>>>>>> ,there is one that have the squares more smaller that the other,
>>>>>>>> but i
>>>>>>>> dont want lose any data, i need that in the map it has seen like
>>>>>>>> the figure "A and B" but in the data each row got the values of A
>>>>>>>> and
>>>>>>>> the
>>>>>>>> values of B
>>>>>>>> __________________
>>>>>>>> | 1 | shp=A
>>>>>>>> |_________________|
>>>>>>>> __________________
>>>>>>>> | 2 | 2 |
>>>>>>>> |________|________|
>>>>>>>> | 2 | 2 | shp=B
>>>>>>>> |________|________|
>>>>>>>> | 2 | 2 |
>>>>>>>> |________|________|
>>>>>>>> is
>>>>>>>> a
>>>>>>>> like
>>>>>>>> this
>>>>>>>> __________________
>>>>>>>> | 1,2 | 1,2 |
>>>>>>>> |________|________|
>>>>>>>> | 1,2 | 1,2 | shp=A and B
>>>>>>>> |________|________|
>>>>>>>> | 1,2 | 1,2 |
>>>>>>>> |________|________|
>>>>>>>> dni12B numeric,dniannB numeric,the_geom geometry
>>>>>>>> i think that this is posible to do with postgis, but i dont know
>>>>>>>> why,
>>>>>>>> am
>>>>>>>> looking in quantumGIS but i lose data cause the big suare overlap
>>>>>>>> the
>>>>>>>> little
>>>>>>>> ones and i lose data cause there is some places that i get NULL.
>>>>>>>> please help
>>>>>>>> thanks for all
>>>>>>>>> On Mon, Dec 9, 2013 at 11:03 AM, J.Alejandro Martinez Linares <
>>>>>>>>> islanis at infomed.sld.cu> wrote:
>>>>>>>>>> Hi People, i need your help, let say that i have 2 shapefiles
>>>>>>>>>> __________________
>>>>>>>>>> | 1 | shp=B
>>>>>>>>>> |_________________|
>>>>>>>>>> One big country, this is a multipolygon shape
>>>>>>>>>> __________________
>>>>>>>>>> | 2 | 2 |
>>>>>>>>>> |________|________|
>>>>>>>>>> | 2 | 2 | shp=B
>>>>>>>>>> |________|________|
>>>>>>>>>> | 2 | 2 |
>>>>>>>>>> |________|________|
>>>>>>>>>> this
>>>>>>>>>> is
>>>>>>>>>> a multipolygon shape too
>>>>>>>>>> something
>>>>>>>>>> like this
>>>>>>>>>> __________________
>>>>>>>>>> | 1,2 | 1,2 |
>>>>>>>>>> |________|________|
>>>>>>>>>> |________|________|
>>>>>>>>>> | 1,2 | 1,2 |
>>>>>>>>>> |________|________|
>>>>>>>>>> i think that this is posible, please help me to get somthing like
>>>>>>>>>> this i need it.
>>>>>>>>>> Este mensaje le ha llegado mediante el servicio de correo
>>>>>>>>>> electronico
>>>>>>>>>> que ofrece Infomed para respaldar el cumplimiento de las misiones
>>>>>>>>>> del
>>>>>>>>>> Sistema Nacional de Salud. La persona que envia este correo asume
>>>>>>>>>> el
>>>>>>>>>> compromiso de usar el servicio a tales fines y cumplir con las
>>>>>>>>>> regulaciones
>>>>>>>>>> establecidas
>>>>>>>>>> Infomed: http://www.sld.cu/
>>>>>>>>>> _______________________________________________
>>>>>>>>>> postgis-users mailing list
>>>>>>>>>> postgis-users at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>>>>>> This message was sent using IMP, the Internet Messaging Program.
>>>>>>>> electronico
>>>>>>>> que
>>>>>>>> ofrece Infomed para respaldar el cumplimiento de las misiones del
>>>>>>>> Sistema
>>>>>>>> Nacional de Salud. La persona que envia este correo asume el
>>>>>>>> compromiso
>>>>>>>> de
>>>>>>>> usar el servicio a tales fines y cumplir con las regulaciones
>>>>>>>> establecidas
>>>>>> Este mensaje le ha llegado mediante el servicio de correo electronico
>>>>>> que
>>>>>> Sistema
>>>>>> compromiso
>>>>>> de
>>>>>> establecidas
>>>> que
>>>> Sistema
>>>> Nacional de Salud. La persona que envia este correo asume el compromiso
>>>> de
>>>> establecidas
>> Este mensaje le ha llegado mediante el servicio de correo electronico que
>> ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema
>> Nacional de Salud. La persona que envia este correo asume el compromiso de
>> usar el servicio a tales fines y cumplir con las regulaciones establecidas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131214/54550d61/attachment.html>
