[postgis-users] Errors while creating database from org.geotools.data.postgis
Thomas Schweikle
tschweikle at gmail.com
Thu Dec 19 07:53:34 PST 2013
Hi!
I am seeing various errors while a routine tries to create databases.
I'm having trouble interpreting these errors:
--- SNIP
18:35:34,895 ERROR Dez 18, 2013 6:35:34 PM
org.geotools.data.postgis.PostgisDataStore createSchema
Information: CREATE TABLE "public"."npp" ("npp_fid" serial PRIMARY
KEY, "the_geom" GEOMETRY, "Name" VARCHAR(256), "Longitude" DOUBLE
PRECISION, "Latitude" DOUBLE PRECISION);
--- SNAP
To me it looks like they are trying to create a database, but without
rights to create the database? Any way to find the user whom is to
create this database?
--- SNIP
18:35:35,069 ERROR Dez 18, 2013 6:35:35 PM
Information: DELETE FROM GEOMETRY_COLUMNS WHERE f_table_catalog='' AND
f_table_schema = 'public'AND f_table_name = 'npp';
--- SNAP
They want to delete datasets, but fail. Access rights wrong? Wrong
user? Which user was intended? Which user was used? Or -- is this
database not enabled to use postgis??
--- SNIP
18:35:35,080 ERROR Dez 18, 2013 6:35:35 PM
Information: INSERT INTO GEOMETRY_COLUMNS VALUES
('','public','npp','the_geom',2,4326,'POINT');
18:35:35,089 ERROR Dez 18, 2013 6:35:35 PM
Information: ALTER TABLE "public"."npp" ADD CONSTRAINT
enforce_srid_the_geom CHECK (SRID(the_geom) = 4326);
18:35:35,097 ERROR Dez 18, 2013 6:35:35 PM
enforce_dims_the_geom CHECK (ndims(the_geom) = 2);
18:35:35,123 ERROR Dez 18, 2013 6:35:35 PM
enforce_geotype_the_geom CHECK (geometrytype(the_geom) = 'POINT'::text
OR the_geom IS NULL);
18:35:35,133 ERROR Dez 18, 2013 6:35:35 PM
Information: CREATE INDEX "spatial_npp_the_geom" ON "public"."npp"
USING GIST ("the_geom");
--- SNAP
Maybe someone 's got an idea how to find out what was going on here!
Thomas
