[postgis-users] Errors while creating database from org.geotools.data.postgis
Andy Colson andy at squeakycode.net
Thu Dec 19 09:44:09 PST 2013
On 12/19/2013 9:53 AM, Thomas Schweikle wrote:
> Hi!
> I am seeing various errors while a routine tries to create databases.
> I'm having trouble interpreting these errors:
> --- SNIP
> 18:35:34,895 ERROR Dez 18, 2013 6:35:34 PM
> org.geotools.data.postgis.PostgisDataStore createSchema
> Information: CREATE TABLE "public"."npp" ("npp_fid" serial PRIMARY
> KEY, "the_geom" GEOMETRY, "Name" VARCHAR(256), "Longitude" DOUBLE
> PRECISION, "Latitude" DOUBLE PRECISION);
> --- SNAP
> To me it looks like they are trying to create a database, but without
> rights to create the database? Any way to find the user whom is to
> create this database?
> --- SNIP
> 18:35:35,069 ERROR Dez 18, 2013 6:35:35 PM
> Information: DELETE FROM GEOMETRY_COLUMNS WHERE f_table_catalog='' AND
> f_table_schema = 'public'AND f_table_name = 'npp';
> --- SNAP
> They want to delete datasets, but fail. Access rights wrong? Wrong
> user? Which user was intended? Which user was used? Or -- is this
> database not enabled to use postgis??
> --- SNIP
> 18:35:35,080 ERROR Dez 18, 2013 6:35:35 PM
> Information: INSERT INTO GEOMETRY_COLUMNS VALUES
> ('','public','npp','the_geom',2,4326,'POINT');
> 18:35:35,089 ERROR Dez 18, 2013 6:35:35 PM
> Information: ALTER TABLE "public"."npp" ADD CONSTRAINT
> enforce_srid_the_geom CHECK (SRID(the_geom) = 4326);
> 18:35:35,097 ERROR Dez 18, 2013 6:35:35 PM
> enforce_dims_the_geom CHECK (ndims(the_geom) = 2);
> 18:35:35,123 ERROR Dez 18, 2013 6:35:35 PM
> enforce_geotype_the_geom CHECK (geometrytype(the_geom) = 'POINT'::text
> OR the_geom IS NULL);
> 18:35:35,133 ERROR Dez 18, 2013 6:35:35 PM
> Information: CREATE INDEX "spatial_npp_the_geom" ON "public"."npp"
> USING GIST ("the_geom");
> --- SNAP
> Maybe someone 's got an idea how to find out what was going on here!
This doesn't look like the PostgreSQL error log, is it?
1'st I'd say find the error log from PG, not from geotools.
2'nd, in your postgresql.conf make sure your log_line_prefix has things
like %d (databasename) and %u (username)
-Andy
