[postgis-users] help with the Union of 2 shp
islanis at infomed.sld.cu islanis at infomed.sld.cu
Thu Dec 19 10:19:06 PST 2013
"Rémi Cura" <remi.cura at gmail.com> escribió:
> most likely you havn't !
> I don't know your os so answering is difficult.
y have XP sp2, and 1Gb of ram, dual core 1.6ghz
> If you have the size of fb free on list,
> you can try a
> VACUUM FULL ANALYZE
> then try again =)
> Other wise, you may have to do you computing piece by piece.
how can i do this
> Cheers,
> Rémi-C
> 2013/12/19 <islanis at infomed.sld.cu>
>> ok i execute this:
>> DROP TABLE IF EXISTS SPLITED;
>> CREATE TABLE SPLITED AS
>> SELECT ST_Split(b.the_geom,z.the_geom) AS the_geom
>> FROM public.mapa_base_141213 b, public.all_lines_merged z;
>> UPDATE SPLITED SET the_geom = ST_SetSRID(the_geom,4326);
>> SELECT Populate_Geometry_Columns('public.SPLITED'::regclass);
>> ALTER TABLE SPLITED ADD column gid serial;
>> ALTER TABLE SPLITED ADD COLUMN dato character varying;
>> ALTER TABLE SPLITED ADD PRIMARY KEY (gid);
>> DROP TABLE IF EXISTS collectionExtracted;
>> CREATE TABLE collectionExtracted AS
>> SELECT ST_CollectionExtract(b.the_geom,3) AS the_geom
>> FROM public.SPLITED b;
>> SELECT Populate_Geometry_Columns('public.collectionExtracted'::regclass);
>> ALTER TABLE collectionExtracted ADD column gid serial;
>> ALTER TABLE collectionExtracted ADD COLUMN dato character varying;
>> ALTER TABLE collectionExtracted ADD PRIMARY KEY (gid);
>> DROP TABLE IF EXISTS dumped;
>> CREATE TABLE dumped AS
>> SELECT (ST_Dump(b.the_geom)).geom AS the_geom
>> FROM public.rad_solar_directa b;
>> UPDATE dumped SET the_geom = ST_SetSRID(the_geom,4326);
>> SELECT Populate_Geometry_Columns('public.dumped'::regclass);
>> ALTER TABLE dumped ADD column gid serial;
>> ALTER TABLE dumped ADD COLUMN dato character varying;
>> ALTER TABLE dumped ADD PRIMARY KEY (gid);
>> and i get this error
>> ERROR:  no se pudo extender el archivo «base/604204/609808.5»: No space
>> left on device
>> HINT:  Verifique el espacio libre en disco.
>> ********** Error **********
>> left on device
>> Estado SQL:53100
>> Sugerencias:Verifique el espacio libre en disco.
>> and i have 11,5Gb of free space what can i do to solve this problem now.
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
