[postgis-users] help with the Union of 2 shp
J.Alejandro Martinez Linares
islanis at infomed.sld.cu
Sat Dec 21 17:02:13 PST 2013
El 19/12/13 19:22, Rémi Cura escribió:
> it is a regular sql command :
> use pgadmin or psql
> vacuum full analyze;
Remi i'll do a full analysis vacuum to my DB ok.
> To execute by pieces, there are many possibilities,
> one would be to use pgscript.
> The idea is to split your big query into smaller queries.
Remi
and , how can i do it, i mean, how can i split my big query, in the case
of only this
"CREATE TABLE SPLITED AS
SELECT ST_Split(b.the_geom,z.the_geom) AS the_geom
FROM public.mapa_base_141213 b, public.all_lines_merged z;"
> Cheers,
> Rémi-C
> 2013/12/19 <islanis at infomed.sld.cu <mailto:islanis at infomed.sld.cu>>
> "Rémi Cura" <remi.cura at gmail.com <mailto:remi.cura at gmail.com>>
> escribió:
> most likely you havn't !
> I don't know your os so answering is difficult.
> y have XP sp2, and 1Gb of ram, dual core 1.6ghz
> If you have the size of fb free on list,
> you can try a
> VACUUM FULL ANALYZE
> then try again =)
> Other wise, you may have to do you computing piece by piece.
> how can i do this
> Cheers,
> Rémi-C
> ok i execute this:
> DROP TABLE IF EXISTS SPLITED;
> UPDATE SPLITED SET the_geom = ST_SetSRID(the_geom,4326);
> SELECT Populate_Geometry_Columns('public.SPLITED'::regclass);
> ALTER TABLE SPLITED ADD column gid serial;
> ALTER TABLE SPLITED ADD COLUMN dato character varying;
> ALTER TABLE SPLITED ADD PRIMARY KEY (gid);
> DROP TABLE IF EXISTS collectionExtracted;
> CREATE TABLE collectionExtracted AS
> SELECT ST_CollectionExtract(b.the_geom,3) AS the_geom
> FROM public.SPLITED b;
> SELECT
> Populate_Geometry_Columns('public.collectionExtracted'::regclass);
> ALTER TABLE collectionExtracted ADD column gid serial;
> ALTER TABLE collectionExtracted ADD COLUMN dato character
> varying;
> ALTER TABLE collectionExtracted ADD PRIMARY KEY (gid);
> DROP TABLE IF EXISTS dumped;
> CREATE TABLE dumped AS
> SELECT (ST_Dump(b.the_geom)).geom AS the_geom
> FROM public.rad_solar_directa b;
> UPDATE dumped SET the_geom = ST_SetSRID(the_geom,4326);
> SELECT Populate_Geometry_Columns('public.dumped'::regclass);
> ALTER TABLE dumped ADD column gid serial;
> ALTER TABLE dumped ADD COLUMN dato character varying;
> ALTER TABLE dumped ADD PRIMARY KEY (gid);
> and i get this error
> ERROR: no se pudo extender el archivo
> «base/604204/609808.5»: No space
> left on device
> HINT: Verifique el espacio libre en disco.
> ********** Error **********
> left on device
> Estado SQL:53100
> Sugerencias:Verifique el espacio libre en disco.
> and i have 11,5Gb of free space what can i do to solve
> this problem now.
> This message was sent using IMP, the Internet Messaging Program.
> Este mensaje le ha llegado mediante el servicio de correo
> electronico que ofrece Infomed para respaldar el cumplimiento de
> las misiones del Sistema Nacional de Salud. La persona que envia
> este correo asume el compromiso de usar el servicio a tales fines
> y cumplir con las regulaciones establecidas
> Infomed: http://www.sld.cu/
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131222/33c8f720/attachment.html>
