[postgis-users] Advice on Unioning Polygons
pcreso at pcreso.com
Fri Feb 1 02:57:48 PST 2013
Hi Rebecca,
Sounds like you are doing this in a script, but you didn't specify your OS.
If so, then as each iteration completes, you can accumulate the id's of the polygons dealt to already, & test against this list to avoid creating the duplicates. Either in a file or in a table.
Along the lines of:
for polygon in <list of polygon ids> do
if id not in list of unioned id's; then
add ids to be unioned in this iteration to the list of unioned ones
union them
end of if
move to next polygon id
You might consider making the unioned polygons a multipolygon, just in case some of them are.
There are improved functions & performance with later versions of postgres & postgis, so you might consider upgrading.
HTH,
Brent Wood
--- On Fri, 2/1/13, Rebecca Clarke <r.clarke83 at gmail.com> wrote:
Subject: [postgis-users] Advice on Unioning Polygons
To: postgis-users at lists.osgeo.org
Date: Friday, February 1, 2013, 11:40 PM
Hi there
Looking for some advice.
I have a table with thousands of polygon records.
I want to union all intersecting polygons that have the same attributes into one polygon (So one record, rather than 10 or 20 etc.).
Can anyone recommend the best way to do this.
I can do a loop which goes through each record, unions its geometry with the geometry's of the other matching records that intersect with it, then move to the next record. Problem with this is that it creates duplicate polygons when it comes to a record that has already been unioned with a previous one record. I can easily delete any duplicate records generated, but I'm wondering if there's a less long winded way.
I hope I'm explaining myself correctly.
My details are:postgis 1.3.5PostgreSQL 8.3.8
Many thanks in advance.
Rebecca
-----Inline Attachment Follows-----
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130201/5ffa7c92/attachment.html>
