[postgis-users] (no subject)
Francois Hugues
hugues.francois at irstea.fr
Sat Feb 2 00:14:49 PST 2013
I think this is a tolerance issue. If you try
select st_distance(ST_MakeEnvelope(-105.17353271032549,39.798766541338225,-105.07765728967452,39.83016145866177,4326), st_setsrid(ST_MakePOint(-105.130637 ,39.830165),4326))
The distance is very short : 3.54133823066149e-06
And i you add the where clause, it is also true that your lat is not <= to the given one, so the single line returned with the simple && query is now excluded.
Hugues.
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Pavel Shub
Envoyé : samedi 2 février 2013 07:14
À : postgis-users at lists.osgeo.org
Objet : [postgis-users] (no subject)
Hi all,
Please tell me if I'm doing something incorrectly, but I seem to be getting wrong results for the following bounding box query:
select * from geotest where geom && ST_MakeEnvelope(-105.17353271032549,39.798766541338225,-105.07765728967452,39.83016145866177,4326)
Given table with columns: name (varchar), lat (double), lon (double), geom (geometry). geom having srid 4326 points
A row with lat = 39.830165, lon = -105.130637 is returned. I find this very peculiar because the latitude is greater than the maxiumum latitude in the envelope (39.83016145866177). If I then add a 'and lat <= 39.83016145866177' clause, the row is no longer returned.
I noticed this on postgres 9.1 with postgis 1.5 then when testing again got the same results on postgres 9.2 and postgis 2.0
Is this intended and I missed some documentation somewhere, or is this an issue?
Thank you,
Pavel Shub
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130202/54b930e1/attachment.html>
