[postgis-users] ST_SimplifyPreserveTopology and ST_Simplify does not preserve measures
Egil Möller
egil at skytruth.org
Thu Feb 7 07:52:22 PST 2013
POSTGIS="1.4.0" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.7.1, 23 September
2009" USE_STATS
So yes, this is an older system. If it works fine in a newer version I
guess I should consider the issue closed :)
On 02/08/2013 01:37 AM, Nicolas Ribot wrote:
> By the way, wich Pgis version ?
> On POSTGIS="2.0.2 r10789" , it gives correct result:
> select st_astext(st_simplify('LINESTRINGM(0 0 0, 1 1 1, 10 10
> 10)'::geometry, 1));
> st_astext
> LINESTRING M (0 0 0,10 10 10)
> (1 row)
> Nicolas
> On 7 February 2013 16:33, Nicolas Ribot <nicolas.ribot at gmail.com
> <mailto:nicolas.ribot at gmail.com>> wrote:
> Sorry, answered to fast... ;)
> Don't know with it drops M dimension.
> On 7 February 2013 16:28, Nicolas Ribot <nicolas.ribot at gmail.com
> Hi,
> You are simplifying data with a 1000 degrees tolerance !
> Project your data into a planar system, then simplify it.
> Nicolas
> On 7 February 2013 15:59, Egil Möller <egil at skytruth.org
> <mailto:egil at skytruth.org>> wrote:
> It seems like ST_SimplifyPreserveTopology and ST_Simplify
> does not
> preserve measure coordinates and mangles my linestringm to
> an ordinary
> linestring. Why is that? It seems like a rather random
> limitation!
> mydb=> select ST_AsEWKT(line) from ais_path limit 1;
> SRID=4326;LINESTRINGM(102.647916667 5.63022166667
> 1357100014,102.647916667 5.63022166667 1357446366)
> mydb=> select ST_AsEWKT(ST_SimplifyPreserveTopology(line,
> 1000)) from
> ais_path limit 1;
> SRID=4326;LINESTRING(102.647916667
> 5.63022166667,102.647916667
> 5.63022166667)
> Best regards,
> Egil
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> <mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130208/97610428/attachment.html>
