[postgis-users] ST_SimplifyPreserveTopology and ST_Simplify does not preserve measures
Egil Möller
egil at skytruth.org
Thu Feb 7 08:39:57 PST 2013
Nope. I'm already using ST_AsEWKT. See the code example in my original
mail...
On 02/08/2013 02:37 AM, Sandro Santilli wrote:
> On Fri, Feb 08, 2013 at 01:52:22AM +1000, Egil Möller wrote:
>> POSTGIS="1.4.0" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.7.1, 23 September
>> 2009" USE_STATS
>> So yes, this is an older system. If it works fine in a newer version I
>> guess I should consider the issue closed :)
> It's actually always preserved M. It's ST_AsText that dropped it
> in 1.4 because at that time OGC specs did not have M, and ST_AsText
> was an OGC-following function. Try AsEWKT.
> --strk;
> http://www.cartodb.com - Map, analyze and build applications with your data
> ~~ http://strk.keybit.net
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
