[postgis-users] tiger data pain
Andy Colson
andy at squeakycode.net
Thu Feb 7 14:18:04 PST 2013
On 12/13/2011 10:35 PM, Stephen Woodbridge wrote:
> On 12/13/2011 10:16 PM, Andy Colson wrote:
>> I downloaded PostGis 2 to play around with, and tried out the tiger
>> stuff. I have to say, that's kinda painful.
>> The doc says: add "set -e -u", which causes as many problems as it might
>> catch.
>> Editing the .sql was a little confusing, and the resulting .sh file is
>> not really re-startable.
>> Would anyone be interested in a perl script to simplify things? I'm
>> thinking of replacing the stored proc that generates a script, all of
>> which you have to edit, with a perl script (which would have a config to
>> edit).
>> Or... maybe other's have not had the problems I had? I don't really have
>> a use for this right now, just playing around. If anyone had some
>> requests, I might be interested in working on it.
> Andy,
> I think this would be a good idea. One trick I use a lot with Perl is
> find2perl which I use to walk a directory structure like the Tiger
> source tree to find the files I want to load.
> Also Census just released the Tiger2011 files, unfortunately, they have
> only released them in the type directory structure and not in the state
> directory structure. Each year there are file name changes and column
> name changes within the files. I think using Perl would make it easier
> to remap these column names.
> -Steve
> postgis-users mailing list
Its only been a year... not to bad for a turn around time :-)
I started on a perl program to import data, but then got side tracked
and forgot about it.
Few weeks ago I needed to pull more data, so I dusted off my script,
cleaned it up, ran it, and published it:
https://github.com/AndyColson/tigerLoader
It only does 2010 data, and I might have gotten carried away with the
threads. I'm not sure how easy it'll be for others to use.
But there it is.
-Andy
