[postgis-users] Is it worth to load background raster into postgis?
Pietro Rossin pierigis at gmail.com
Fri Feb 8 11:27:35 PST 2013
We don't have a WMS server yet, any suggestion for a "not too difficult to
configure" solution?
p
2013/2/8 Paolo Cavallini [via PostGIS] <ml-node+s17n5002552h36 at n6.nabble.com
> Il 08/02/2013 14:19, Pietro Rossin ha scritto:
> > Hi
> > Thanks Paolo
> > How can I store my images to be served as WMS?
> any format that can by read by your WMS server; most probably gdalinfo
> --formats
> > I don't know if these performances could be the same with raster...
> > I mean, if I load the ecw's on a postgis database, which could be the
> > ratio on disk space between ecw compressed image and raster table?
> certainly unfavourable for PG
> > The refreshing of views are as fast as with ecw?
> no
> > Does the postgis database grow up too much with raster?
> I do not know what is too much for you, certainly it will increase a lot.
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> postgis-users mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5002552&i=0>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>  If you reply to this email, your message will be added to the discussion
> below:
> http://postgis.17.n6.nabble.com/Is-it-worth-to-load-background-raster-into-postgis-tp5002525p5002552.html
>  To unsubscribe from Is it worth to load background raster into postgis?, click
> here<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5002525&code=cGllcmlnaXNAZ21haWwuY29tfDUwMDI1MjV8MjMwODY1MTQ5>
> NAML<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://postgis.17.n6.nabble.com/Is-it-worth-to-load-background-raster-into-postgis-tp5002525p5002553.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130208/11060edd/attachment.html>
