[postgis-users] Calculating the maximum minimal distance between two points
Paragon Corporation
lr at pcorp.us
Mon Feb 11 01:14:09 PST 2013
If you are using PostGIS 1.5, 2.0 ST_MaxDistance is probably what you are
looking for:
http://postgis.net/docs/manual-2.0/ST_MaxDistance.html
In conjunction with:
http://postgis.net/docs/manual-2.0/ST_DWithin.html
Hope that helps,
Regina
http://www.postgis.us
_____
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of José Pedro
Santos
Sent: Monday, February 11, 2013 3:54 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Calculating the maximum minimal distance
between two points
Hi Carsten,
You can check that in this link
http://postgis.refractions.net/documentation/manual-1.3/ch06.html see the
chapter 6.1.2. Geometry Relationship Functions.
Best Regards,
José Santos
_____
Date: Fri, 8 Feb 2013 17:00:31 +0100
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Calculating the maximum minimal distance between
two points
I've got two point layer.
I want to identify the maximum distance of the nearest neighbour point.
How could it be possible?
Thank for every help.
Carsten
_______________________________________________ postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130211/ae4b7154/attachment.html>
