[postgis-users] Viewing the PostGIS in Action examples in QGIS
Atle Frenvik Sveen atle.sveen at bouvet.no
Tue Feb 12 23:24:58 PST 2013
Well, it seems as though you've misunderstood a bit. Your query executed fine, but it was a SELECT query, so all it did was running the ST_Point() function and displaying the result. Nothing stored in no tables, so i'd be very supried if you found it again somewhere.
If I rememeber correctly the book covers creating spatial columns, loading and storing data, so I suggest you gather some patience and continue the book :)
Good luck!
-atle
 Atle Frenvik Sveen / 54°23'55"S 3°24'5"E
Konsulent
Bouvet Norge AS, Kjøpmannsgata 35, NO-7011 Trondheim
Tlf +47 75 53 70 00 Mobil +47 45 27 86 89
http://www.bouvet.no   atle.sveen at bouvet.no
From: postgis-users-bounces at lists.osgeo.org [postgis-users-bounces at lists.osgeo.org] on behalf of Charles Sprowal [uchihabarles at gmail.com]
Sent: Wednesday, February 13, 2013 7:50 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Viewing the PostGIS in Action examples in QGIS
Hello,
     I have just started reading through the book PostGIS In Action in an attempt to learn Postgis, but have encountered a problem right at the start. After creating a spatially enabled database, the text asks me to run the following sql:
SELECT ST_Point(1, 2) AS MyFirstPoint;
The query ran successfully. If I understand correctly, that statement creates a point in the db. After installing QuantumGIS and accessing the database through it, I expected to be able to view the point, but I could not. I had a similar problem with another query in the same chapter that's supposed to generate a heart-shaped polygon:
SELECT ST_GeomFromText('LINESTRING(52 218, 139 82, 262 207, 245 261, 207 267,
153 207, 125 235, 90 270, 55 244, 51 219, 52 218)') AS HeartLine;
When I connect to the database through QGIS, I get the following log message: "Database connection was successful, but the accessible tables could not be determined." The only table that is listed as having geometry (table "raster_columns" under schema "public") does not seem to contain the point. I cannot even select the table to add a layer from it.
I've followed the instructions in chapter 12.3 for QGIS use and remain at a loss. Any idea where I'm going wrong?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130213/70fc590d/attachment.html>
