[postgis-users] Query without index faster than query with index (using GIST)
Stephen Woodbridge woodbri at swoodbridge.com
Thu Feb 14 16:20:57 PST 2013
In addition you need to tell us what version of software you are running.
select postgis_full_version();
In the newer versions many of the ST_* function automatically do and
appropriate && under the covers so adding it in does not improve
anything, but dos make you query backwards compatible with older versions.
-Steve W
On 2/14/2013 7:06 PM, Andy Colson wrote:
> Try running the same query three or four times in a row.  I'll bet you
> get a different time for each of them.
> Your numbers are way to close together to say that one is faster than
> the other.
> -Andy
> On 02/14/2013 05:36 PM, Marcello Benigno wrote:
>> Hello everybody,
>> I wonder why this is happening, all tables are with indexes and has
>> already run a vacuum analyze to all of them:
>> SELECT ms_ucs,
>> SUM(ST_Area(Geography((ST_Intersection(analises.pol_geom,ms_2010_s1.geom)))))/10000
>> AS area_ha
>> FROM analises, ms_2010_s1
>> WHERE analises.pol_geom && ms_2010_s1.geom
>> AND ST_Intersects(analises.pol_geom,ms_2010_s1.geom)
>> GROUP BY ms_ucs; *-- 889 ms*
>> SELECT ms_ucs,
>> AS area_ha
>> WHERE ST_Intersects(analises.pol_geom,ms_2010_s1.geom)
>> GROUP BY ms_ucs; *-- 870 ms !!!*
>> Please note that the second, without using the && operator was faster,
>> there's something wrong or I'm not understanding the functioning of
>> the index?
>> Thanks in advance,
>> *Marcello Benigno B. de Barros Filho*
>> Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
>> Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
>> Doutorando em Tecnologia Ambiental e Recursos Hídricos - UFPE
>> http://profmarcello.blogspot.com
>> http://about.me/marcello.benigno
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
