[postgis-users] Perplexed: ST_Intersects with Geography, odd results
Jensen, Layne K CIV SPAWARSYSCEN-PACIFIC, 56210 layne.jensen at navy.mil
Tue Feb 19 07:25:41 PST 2013
We are using PostgreSQL version 9.2.2 with PostGIS 2.0,and need to do simple queries to find points that are within or intersect with a polygon.
The following test case returns only partial results for an unknown reason. If the minimum longitude value of the polygon is changed from 0 to 1 to 2 to 5 to 20 (leaving the latitudes limits as they are), different numbers of the points are returned, even though all of the points fall into the polygon for all these values.
CREATE TABLE testing.tsttab
  lat real,
  lon real,
  tstpoint geography(Point,4326)
INSERT INTO testing.tsttab (lat, lon, tstpoint) values (36.1, 22.1, ST_GeographyFromText('POINT(22.1 36.1)'));
INSERT INTO testing.tsttab (lat, lon, tstpoint) values (36.2, 22.2, ST_GeographyFromText('POINT(22.2 36.2)'));
INSERT INTO testing.tsttab (lat, lon, tstpoint) values (36.3, 22.3, ST_GeographyFromText('POINT(22.3 36.3)'));
INSERT INTO testing.tsttab (lat, lon, tstpoint) values (36.4, 22.4, ST_GeographyFromText('POINT(22.4 36.4)'));
INSERT INTO testing.tsttab (lat, lon, tstpoint) values (36.5, 22.5, ST_GeographyFromText('POINT(22.5 36.5)'));
INSERT INTO testing.tsttab (lat, lon, tstpoint) values (36.6, 23.1, ST_GeographyFromText('POINT(23.1 36.6)'));
INSERT INTO testing.tsttab (lat, lon, tstpoint) values (36.7, 23.2, ST_GeographyFromText('POINT(23.2 36.7)'));
select * from testing.tsttab
where st_intersects(
st_geogfromtext('POLYGON((2 35, 2 37, 40 37, 40 35, 2 35))'),tstpoint);
If we convert to GEOMETRY rather than GEOGRAPHY, it performs correctly. Can anyone shed light on what we are doing wrong?
Thank you!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130219/26a5ed0b/attachment.html>
Type: application/x-pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130219/26a5ed0b/attachment.bin>
