[postgis-users] ST_SetSRID
Bborie Park dustymugs at gmail.com
Thu Feb 21 06:57:38 PST 2013
Your query needs a FROM clause to specify the table.  The error
message is indicating that the database does not know the "rast"
column...
SELECT rast As bd_ortho, ST_Transform(rast,4326) As bd_ortho_wgs84 FROM mytable
Also, you really should upgrade your PostGIS installation to 2.0.1.
-bborie
On Thu, Feb 21, 2013 at 2:36 AM, laurent
<lcelati at latitude-geosystems.com> wrote:
> Hello,
> SELECT postgis_full_version()
> "POSTGIS="2.0.0 r9605" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.8.0, 6 March
> 2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
> LIBJSON="UNKNOWN" RASTER"
> Yes, yesterday i tried to do a reprojection thanks to st_transform & to do a
> ST_SetSRID in order to update metadata but eventually I do not think I
> succeeded.
> Could you tell me the SQL query please? I thought that following queries are
> valid :
> But i have today an error message saying :
> ERREUR:  la colonne « rast » n'existe pas
> LINE 1: SELECT rast As bd_ortho, ST_Transform(rast,4326) As bd_ortho...
> Once I'm sure I reprojected this layer, I will try to update the metadata
> Thank you to throw light for me.
> Regards.
> View this message in context: http://postgis.17.n6.nabble.com/ST-SetSRID-tp5002645p5002650.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
