[postgis-users] 2.0.2 ST_GeomFromGeoJson-problem
Sandro Santilli strk at keybit.net
Tue Feb 26 01:59:12 PST 2013
On Mon, Feb 25, 2013 at 10:20:38PM +0100, Tore Halset wrote:
> Hello.
> POSTGIS="2.0.2 r10789" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8" LIBJSON="UNKNOWN" RASTER
The version seems fine.
Could you please file a new ticket with the offending query attached
as an .sql file ? Also report in the ticket the version of libjson-c
you're using (as you can see PostGIS is unable to tell).
--strk;
 http://www.cartodb.com - Map, analyze and build applications with your data
                                       ~~ http://strk.keybit.net
