[postgis-users] json_tokener_errors
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Feb 26 12:47:04 PST 2013
Does the file exits?
ls /usr/lib/postgresql/9.1/lib/postgis-2.0.so
Also run:
sudo ldconfig
to make sure cache is updated.
-Steve W
On 2/26/2013 3:41 PM, Nathan Hemenway wrote:
> I am hoping someone has a solution to this issue that I have seen
> lurking around compiling POSTGIS with JSON-C etc.
> Everything seems to compile a-okay - GEOS, PROJ, JSON-C, XMLLIB2, and
> POSTGIS
> after the final make install of postgis when I attempt my first
> spatialize on db:
> psql -f /usr/share/postgresql/9.1/contrib/postgis-2.0/postgis.sql -d
> template1
> psql:/usr/share/postgresql/9.1/contrib/postgis-2.0/postgis.sql:49:
> ERROR: could not load library "/usr/lib/postgresql/9.1/lib/postgis-
> 2.0.so": /usr/lib/postgresql/9.1/lib/postgis-2.0.so: undefined symbol:
> json_tokener_errors
> Here is ldd on postgis lib:
> ldd /usr/lib/postgresql/9.1/lib/postgis-2.0.so
> linux-vdso.so.1 => (0x00007fffefbfd000)
> libgeos_c.so.1 => /usr/local/lib/libgeos_c.so.1
> (0x00002aee23949000)
> libproj.so.0 => /usr/local/lib/libproj.so.0 (0x00002aee23b6b000)
> libxml2.so.2 => /usr/local/lib/libxml2.so.2 (0x00002aee23db9000)
> libm.so.6 => /lib/libm.so.6 (0x00002aee24123000)
> libc.so.6 => /lib/libc.so.6 (0x00002aee243a6000)
> libgeos-3.3.7.so => /usr/local/lib/libgeos-3.3.7.so
> (0x00002aee246fa000)
> libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00002aee24aa1000)
> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00002aee24dad000)
> libdl.so.2 => /lib/libdl.so.2 (0x00002aee24fc5000)
> libz.so.1 => /usr/lib/libz.so.1 (0x00002aee251c9000)
> /lib64/ld-linux-x86-64.so.2 (0x00002aee23483000)
> Yet here is ldconfig -p | grep json:
> libjson.so.0 (libc6,x86-64) => /usr/local/lib/libjson.so.0
> libjson.so (libc6,x86-64) => /usr/local/lib/libjson.so
> libjson-c.so.2 (libc6,x86-64) => /usr/local/lib/libjson-c.so.2
> libjson-c.so (libc6,x86-64) => /usr/local/lib/libjson-c.so
> And I can say that
> ld.so.conf.d/ includes /usr/local/lib !
> Any ideas?
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
