[postgis-users] Update from spatial query problem
Ulises F-Troche
ufeliciano at yahoo.com
Sun Jan 6 20:14:49 PST 2013
Thanks, Steve...
it worked great! In my statement the last line was missing.
From: Stephen Woodbridge <woodbri at swoodbridge.com>
To: postgis-users at lists.osgeo.org
Sent: Sunday, January 6, 2013 8:56 AM
Subject: Re: [postgis-users] Update from spatial query problem
Sorry, try one of these:
update table2 set area=mytable.name
from (select table1.name, table3.code
from table3, table1
where st_within(table3.geom,table1.geom)) AS mytable
where mytable.code=table2.code;
or
update table2 set area=table1.name
from table3, table1
where st_within(table3.geom, table1.geom)
and table3.code=table2.code;
-Steve
On 1/6/2013 2:26 AM, Ulises F-Troche wrote:
> Thanks for the suggestion, Steve, but when I ran your suggested
> statement, it fail with...
> ERROR: columnn mytable.code do not exists
> LINE 6: where mytable.code=table2.code;
> ********** Error **********
> ERROR: no existe la columna mytable.code
> SQL state: 42703
> Character: 191
> *From:* Stephen Woodbridge <woodbri at swoodbridge.com>
> *To:* postgis-users at lists.osgeo.org
> *Sent:* Thursday, January 3, 2013 2:39 PM
> *Subject:* Re: [postgis-users] Update from spatial query problem
> On 1/3/2013 2:27 PM, Ulises F-Troche wrote:
> > Hi group,
> > I'm new to PostGIS and so far I'm really liking it. I'm trying to
> > update a table based on a spatial query but I have not been able to do
> > it successfully. I have 3 tables as follow:
> > table1 (areas):
> > - id (polygon code)
> > - name (polygon name)
> > - geom (polygon)
> > table2 (non spatial table for persons)
> > - code (person id)
> > - name (person name)
> > - lastname (person last name)
> > - area (area name as appears in table1)
> > table3 (person location)
> > - code (person id)
> > - geom (point)
> > I need to update table2.area (which is null) based on the location of
> > each point in table3. The following query provides the location
> > information required...
> > select table3.*,table1.name
> > from table3,table1
> > where st_within(table3.geom,table1.geom);
> > but when try to create the update statement it is updating all records
> > with the same value (area name), which is the same of the first record
> > returned by the selection query...
> > update table2
> > from (select table1.name <http://table1.name/> <http://table1.name/>
> > from
> > table3,table1
> > where st_within(table3.geom,table1.geom)) AS mytable;
> Your update has no qualifier that says "What record int table2 should
> get updated" so all records are getting updated.
> This might give you better results:
> from table3, table1
> -Steve
> > Any help to figure this out is appreciated.
> > Thanks,
> > Ulises
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130106/3696f066/attachment.html>
