[postgis-users] ST_Transform error
Cedric Duprez
Cedric.Duprez at ign.fr
Wed Jan 9 05:21:49 PST 2013
> Can you try with a new install in another database ?
> If the problem persist please file a ticket with all details.
OK, after install in a new database, ST_Transform works correctly with pre-defined SRIDs.
I still have an error on my custom SRIDs, which is different from the last error:
select *, ST_Transform(ST_SetSRID(ST_MakePoint(xl, yl), 910002), 910001) AS geom
from (values (556866, 1902345) , (689174, 2448195) , (729095, 2528577) , (335755, 2059702) , (623207, 2210468) , (850337, 1871486) , (915275, 1889534) , (639551, 1778327) , (584365, 2273523) , (649599, 2228833)) as t(xl, yl);
ERROR: AddToPROJ4SRSCache: could not parse proj4 string '+init=IGNF:LAMBE' no system list, errno: 2
However, the proj-datumgrid-1.5 was compiled with Proj4.
Any suggestion?
Thanks a lot.
