[postgis-users] clip polygons
Marta Debolini
martadebolini at gmail.com
Tue Jan 15 01:25:32 PST 2013
Thank you all!
I followed your instructions and fixed the problem.
Marta
On Tue, Jan 15, 2013 at 8:16 AM, Francois Hugues
<hugues.francois at irstea.fr>wrote:
> Hello,
> To complete these answers about the usage st_intersection in combination
> with st_intersects, if you want to avoid to clip features "which simply
> intersect the border" you should try to add st_touches(a.geom, b.geom) =
> 'f' in the where clause.
> Hugues
> Hugues FRANÇOIS
> IR - UR DTM
> Cemagref - IRSTEA Grenoble
> 2, rue de la papeterie
> Domaine universitaire
> 38402 Saint-Martin-d'Hères CEDEX
> 04.76.76.27.44
> 06.77.66.21.31
> ________________________________
> From: postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] On Behalf Of Martin Davis
> Sent: Tuesday, January 15, 2013 5:42 AM
> To: postgis-users at lists.osgeo.org
> Subject: Re: [postgis-users] clip polygons
> Correct. See http://postgis.net/docs/manual-2.0/ST_Intersection.html
> On 1/14/2013 5:14 PM, Tim-Hinnerk Heuer wrote:
> I think Nicolas is more correct. St_Intersection sounds like a
> function that gets a geometry while St_Intersects returns a Boolean.
> On Jan 15, 2013 6:24 AM, "Francisco Salas" <
> fsalas at pinar.geocuba.cu> wrote:
> Martha ,
> I think that you must use in the select sentence
> st_intersects(a.the_geom, b.the_geom) as the_geom , instead of a.the_geom
> Francisco Salas
> De: postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] En nombre de Marta Debolini
> Enviado el: lunes, 14 de enero de 2013 12:01 p.m.
> Para: postgis-users at lists.osgeo.org
> Asunto: [postgis-users] clip polygons
> Hi,
> I am a new postgis user, so sorry if my request seems
> trivial for someone.
> I have to clip a polygon with another polygon file. I was
> used to do this operation with the simple comand "clip" in GRASS or QGIS.
> How can I do the same operation in postgis? I tried with
> sy_intersect, but it takes also the polygons outside my area, which simply
> intersect the border.
> The request I wrote is:
> CREATE TABLE w_md.x
> AS (SELECT area, a.the_geom
> FROM oc a, co b
> WHERE st_intersects(a.the_geom, b.the_geom));
> ALTER TABLE w_md.x_1999 ADD column ggid1 serial;
> ALTER TABLE w_mdi.x_1999 ADD PRIMARY KEY (ggID1);
> Thank you for your help,
> Marta
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2013.0.2805 / Virus Database: 2637/6000 - Release Date:
> 12/31/12
> Internal Virus Database is out of date.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130115/4da7d626/attachment.html>
