[postgis-users] Google Maps Polyline to Postgis with Java/Hibernate
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jan 15 08:09:39 PST 2013
You might want to look at GMapToGPX (google it). This is an Javascript
tool that pulls the google map route and converts it to a GPX file. You
might be able to modify this code to access the routing info or to send
the GPX data directly to your server.
I use the tool directly all the time to get the GPX of a route and then
load it into my GPS as a route. It is great for planning trips.
-Steve
On 1/15/2013 11:03 AM, Luciano Borges wrote:
> I have a page where the user enters the starting point and ending point
> and I show de route in the map.
> I would like to know how to get this polygon (polyline) and save it in
> Postgis through the Java / Hibernate.
> For example, I have this code:
> |var request= {
> origin: ptoPartida,
> destination: ptoChegada,
> //provideRouteAlternatives: true,
> travelMode: google.maps.DirectionsTravelMode.DRIVING
> directionsService.route(request, function(response, status) {
> if (status== google.maps.DirectionsStatus.OK) {
> directionsDisplay.setDirections(response);
> console.log(response);
> var*x* = google.maps.geometry.encoding.decodePath(response.routes[0].overview_polyline.points);
> console.log(x);
> The variable *X* is an array of point.
> Now I am looking for send this array to database (postgis).
> After I wiil try recover this data from database and print it on map.
> Thanks, Luciano
> Someone can help me?
> Thanks. Luciano
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
