[postgis-users] selecting a time window
Nicolas Ribot nicolas.ribot at gmail.com
Tue Jan 15 10:48:54 PST 2013
Yes surely, there must be a simpler solution.
Here are some explanations:
-- This first query creates the time windows (or range), asking to generate
a timestamp
-- each 2 seconds, from the first time in the table, to the latest one.
-- This may be replaced by a "group by 2 seconds" range. (I don't know how
to express that)
with buckets as (
select generate_series(min(utc_time), max(utc_time), interval '2') as t
from msg
-- This second query uses the first one and matches each record in the msg
table
-- to a 2 seconds time range. To create a time range, it adds 2 seconds to
each time generated
-- in the first query
, ranges as (
select m.id, m.utc_time, m.lon, m.lat, b.t
from msg m , buckets b
where utc_time >= t and utc_time < (t + interval '2')
order by utc
-- the final query uses the range subquery and counts the number of
utc_times from msg table
-- falling in each time range
select count(utc_time), t
from ranges
group by t
By the way, it should be pretty easy to do it in C#, iterating over records
to see it they fall in a give time range.
Nicolas
On 15 January 2013 18:28, tasneem dewaswala <tasneem.europe at gmail.com>wrote:
> Thanks for you replies,
> Francois, yes it is a regular time window from beginning to end,
> but i din't understand clearly Nicolas solution, is there any other
> simpler way to do this.
> On Mon, Jan 14, 2013 at 5:02 PM, Francois Hugues <
> hugues.francois at irstea.fr> wrote:
>> Hello,
>> I was answering in a similar way to build lines from your data, but I
>> wondered about the time window strategy and its origin. Is it :
>> 1. a regular time from the beginning to the end of your data as Nicolas
>> solution ?
>> 2. a time window for each message : one second before and one second
>> after message of interest or two second before message of interest or two
>> second after message of interest ?
>> In the second case, I think you should use a for loop.
>> Hugues.
>> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
>> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Nicolas Ribot
>> *Sent:* Sunday, January 13, 2013 8:12 PM
>> *To:* PostGIS Users Discussion
>> *Cc:* PostGIS Users Discussion
>> *Subject:* Re: [postgis-users] selecting a time window
>>  Hi,
>> One approach could be to generate 2 seconds intervals from the start time
>> to the end time and then find records that fall in these intervals.
>> You could then group values by interval, or generate linestrings based on
>> the grouped values.
>> The following example uses CTE to express intermediate tables:
>> The mgs table has the following structure:
>>                  Table « public.msg »
>>  Colonne  |           Type           | Modificateurs
>>  id       | integer                  | non NULL
>>  utc_time | timestamp with time zone |
>>  lat      | double precision         |
>>  lon      | double precision         |
>> Index :
>>     "msg_pkey" PRIMARY KEY, btree (id)
>>  1) count the total number of messages within a 2 sec time window, for
>> e.g. msg 1,2,3,4 falls under 2 sec time window,
>>      similarly 5,6,7,8 in next 2 sec.
>> -- generates time buckets of 2 seconds in the range of available times
>> with buckets as (
>> from msg
>> -- associates times with buckets
>> , ranges as (
>> order by utc
>> -- counts the number of utc_times in each time range
>> from ranges
>> group by t
>>   2) draw a linestring using lat/lon values in that 2 sec i.e line from
>> msg 1 to msg 4:
>> Same query as above, except this time points are built from coordinates,
>> then collected into an array and finally passed to st_makeLine to generate
>> geometries.
>> with buckets as (
>> from msg
>> -- flags times in the range of 2s from given times
>> , ranges as (
>> order by utc
>> ) select st_makeLine(array_agg(st_makePoint(lon, lat))) as geom, t
>> from ranges
>> group by t;
>> Nicolas
>> On 12 January 2013 15:42, tasneem dewaswala <tasneem.europe at gmail.com>wrote:
>>> Hello,
>>> I have following data with me
>>> Msg         UTC_Time          Lat                      Lon
>>>    1            133552.25      56.670042           12.862099
>>>   2            133552.75      56.6700403333    12.8621025
>>>   3            133553.25      56.670037           12.862107
>>>   4            133553.5        56.670035           12.8621096667
>>>   5            133554.25      56.6700311667    12.8621146667
>>>   6            133554.75      56.6700303333    12.8621158333
>>>   7            133555.25      56.6700295         12.8621173333
>>>   8            133555.75      56.6700286667    12.8621181667
>>> I need to do following operations
>>> msg 1 to msg 4.
>>> i don't know how can i do this, please give me some suggestions
>>> i am using c# for programming and my postgresql version is
>>> "PostgreSQL 8.4.14, compiled by Visual C++ build 1400, 32-bit"
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130115/768e3c2b/attachment.html>
