[postgis-users] pgbench
Donovan Cameron
sault.don at gmail.com
Wed Jan 16 10:32:10 PST 2013
Hey Jose,
At least on linux, it's part of the postgresql-contrib package and can
be accessed via CLI.
Usage:
pgbench [OPTIONS]... [DBNAME]
Initialization options:
-i invokes initialization mode
-F NUM fill factor
-s NUM scaling factor
Benchmarking options:
-c NUM number of concurrent database clients (default: 1)
-C establish new connection for each transaction
-D VARNAME=VALUE
define variable for use by custom script
-f FILENAME read transaction script from FILENAME
-j NUM number of threads (default: 1)
-l write transaction times to log file
-M {simple|extended|prepared}
protocol for submitting queries to server (default: simple)
-n do not run VACUUM before tests
-N do not update tables "pgbench_tellers" and "pgbench_branches"
-r report average latency per command
-s NUM report this scale factor in output
-S perform SELECT-only transactions
-t NUM number of transactions each client runs (default: 10)
-T NUM duration of benchmark test in seconds
-v vacuum all four standard tables before tests
Common options:
-d print debugging output
-h HOSTNAME database server host or socket directory
-p PORT database server port number
-U USERNAME connect as specified database user
--help show this help, then exit
--version output version information, then exit
Report bugs to <pgsql-bugs at postgresql.org>
If you let the mailing list know what operating system your using for
postgresql then you'll probably get a better answer.
Donovan
On Wed, Jan 16, 2013 at 8:23 AM, José María <jmamuedo at gmail.com> wrote:
> Help!!
> I need use pgbench but I don't know how to install and use this tool!!
> Any idea?
> Thanks
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
