[postgis-users] Google Maps Polyline to Postgis with Java/Hibernate
Jason Greenlaw - NOAA Affiliate
jason.greenlaw at noaa.gov
Wed Jan 16 11:06:05 PST 2013
There may be a better solution, but what I've done in the past with
JPA/Hibernate is to create a varchar field that you can populate with the
WKT representing the polyline (represented in WKT as a LINESTRING), then
configure an 'AFTER INSERT OR UPDATE' trigger which updates the actual
geometry column with the result of ST_GeometryFromText(wkt, srid).
Jason
On Tue, Jan 15, 2013 at 11:38 AM, Luciano Borges <
lucianosantosborges at gmail.com> wrote:
> Hi Steve,
> I took a look at GMapToGPX, but one of the functions it has and I need the
> version 3 of Google Maps already provides me.
> Ex: arrayPoints =
> google.maps.geometry.encoding.decodePath(response.routes[0].overview_polyline.points);
> I need to know how to take that route (array) and convert it into a
> polygon that the postgis can understand.
> Thank you,
> Luciano
> 2013/1/15 Luciano Borges <lucianosantosborges at gmail.com>
>> I have a page where the user enters the starting point and ending point
>> and I show de route in the map.
>> I would like to know how to get this polygon (polyline) and save it in
>> Postgis through the Java / Hibernate.
>> For example, I have this code:
>> var request = {
>> origin: ptoPartida,
>> destination: ptoChegada,
>> //provideRouteAlternatives: true,
>> travelMode: google.maps.DirectionsTravelMode.DRIVING};
>> directionsService.route(request, function(response, status) {
>> if (status == google.maps.DirectionsStatus.OK) {
>> directionsDisplay.setDirections(response);
>> console.log(response);
>> var *x* = google.maps.geometry.encoding.decodePath(response.routes[0].overview_polyline.points);
>> console.log(x);
>> The variable *X* is an array of point.
>> Now I am looking for send this array to database (postgis).
>> After I wiil try recover this data from database and print it on map.
>> Thanks, Luciano
>> Someone can help me?
>> Thanks. Luciano
> Luciano Borges
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130116/2cf70316/attachment.html>
