[postgis-users] Integer geometry type
Paul Ramsey pramsey at opengeo.org
Wed Jan 16 15:34:34 PST 2013
Development work in this vein is ongoing
https://github.com/pramsey/pointcloud
On Wed, Jan 16, 2013 at 1:49 PM, Bruce Rindahl <bruce.rindahl at gmail.com> wrote:
> I am currently building a large PostGIS database of lidar data and going
> through several performance tweaks to make 1.5 billion records respond
> better.  One of the big ones was to convert the z data by multiplying by 100
> and storing it as an integer instead of a double (I know - pretty obvious).
> The resulting reduction in storage space is significant as is query
> performance.  The x and y values are stored as a point value in a geometry
> type which i believe is stored like two double precision values.  Would it
> be possible to specify a special geometry type using integer values instead
> of doubles?  You could either add a factor (and a special SRID) or just
> round the values (possible in my case - are the lidar points really accurate
> to less than a foot?).  D3.js is doing something very similar to this in its
> topoJSON format.
> How much brain damage would this cause?  Just thinking out loud...
> Bruce
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
