[postgis-users] Connecting AutoCAD to PostGIS / setting up a read only user
Christophe Vergon
christophevergon-girtec at orange.fr
Thu Jan 17 08:54:26 PST 2013
Autocad belongs to the windows world, so I think it's a windows account
problem. And with Seven OS it's a little bit tricky.
Mark Volz a écrit :
> Hello,
> Does anyone know if CAD can use a read only account to connect to PostGIS, or do I need an account that had read and write permissions? Also, if anyone has had success at allowing CAD users read only access to PostGIS I would appreciate tips on how to set up the users permissions in PostGIS.
> Background:
> I am having a little bit of trouble connecting a AutoCAD Civil 3-D 2013 Client to PostGRES / PostGIS. Here is what I have so far: Originally I set up read only user account on PostGRES 9.1 / PostGIS 2.0 -64bit. I verified the account works by connecting to PostGIS through qgis, and through ArcMap. CAD unfortunately would not connect. I could see the PostGIS tables however I would get an error if I tried to load the data. At first I thought that the issue was that CAD could not work with PostGRES 9.1 / PostGIS 2.0. However it turns out I can connect to PostGIS if I use the administrator account, instead of the user account that I created.
> Thank You
> Mark Volz
> GIS Specialist
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
