[postgis-users] access is denied in Windows 7
Tumasgiu Rossini
rossini.t at gmail.com
Mon Jan 21 09:35:55 PST 2013
are you running your console with admin privileges ? (Run as Administrator )
2013/1/21 James David Smith <james.david.smith at gmail.com>
> I'm not sure if this is the same issue, but I often have similar problems
> when I am importing data. Have you tried to dump to the 'Data' folder
> within the PostgreSQL installation folder? I think you may find that works
> ok. I think it's permissions for writing to the folder that you are
> getting, rather than accessing the database.
> On 21 January 2013 15:01, Ulises F-Troche <ufeliciano at yahoo.com> wrote:
>> New to postgresql.
>> I'm using PostgreSQL 9.2 in Windows 7. First, to be able to use psql I
>> added the installation path in the system's environment variables. I want
>> to know mre about pg_dump, but when running the command
>> pg_dump -U postgres postgis > c:\myDump.sql
>> I received the error "Access is denied.". I have 3 databases in my
>> machine: postgres, postgis, and template_postgis_20. User postgres is the
>> only role and owner.
>> Any help on how to correctly configure this is appreciated.
>> Thanks
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130121/ebb91516/attachment.html>
