[postgis-users] Why postgis doesn't use index during query?
Nicolas Ribot
nicolas.ribot at gmail.com
Tue Jan 22 07:44:01 PST 2013
In PSQL, \do will list you installed operators:
\do+
List of operators
Schema | Name | Left arg type | Right arg type | Result type |
Description
public | && | geography | geography | boolean |
public | && | geometry | geometry | boolean |
public | && | geometry | raster | boolean |
public | && | raster | geometry | boolean |
public | && | raster | raster | boolean |
public | &&& | geometry | geometry | boolean |
public | &< | geometry | geometry | boolean |
public | &< | raster | raster | boolean |
public | &<| | geometry | geometry | boolean |
public | &<| | raster | raster | boolean |
public | &> | geometry | geometry | boolean |
public | &> | raster | raster | boolean |
public | < | geography | geography | boolean |
public | < | geometry | geometry | boolean |
public | <#> | geometry | geometry | double precision |
public | <-> | geometry | geometry | double precision |
public | << | geometry | geometry | boolean |
public | << | raster | raster | boolean |
public | <<| | geometry | geometry | boolean |
public | <<| | raster | raster | boolean |
And this Pgis doc page describes them:
http://postgis.net/docs/manual-2.0/reference.html#Operators
All st_* predicates internally use GIST operator.
Nicolas
On 22 January 2013 16:39, Pietro Rossin <pierigis at gmail.com> wrote:
> Is there any reference list for the GIST operators?
> Thnx
> Pietro
> 2013/1/22 Pietro Rossin <pierigis at gmail.com>
>> Superthank you!
>> It works and very fast!
>> Bie
>> Pietro
>> 2013/1/22 Nicolas Ribot-2 [via PostGIS] <[hidden email]<http://user/SendEmail.jtp?type=node&node=5002380&i=0>
>>> Hi,
>>> GIST index is only used with GIST operators:
>>> &&, st_intersects, st_touches, etc.
>>> You should rewrite your query to define a geographic bounding box and
>>> test your data against it:
>>> SELECT the_geom, layer, id
>>> FROM gauss_b.polilineegb
>>> where the_geom && 'BOX(2365385 5075215, 2366019 5075752)'::box2d;
>>> Nicolas
>>> On 22 January 2013 15:38, Pietro Rossin <[hidden email]<http://user/SendEmail.jtp?type=node&node=5002378&i=0>
>>> > wrote:
>>>> Hello
>>>> I have a table with about 6.000.000 polilines records.
>>>> The geometry value is in the_geom column.
>>>> I made an index with this instruction
>>>> CREATE INDEX idx_polilineegb_geom
>>>> ON gauss_b.polilineegb
>>>> USING gist
>>>> (the_geom );
>>>> If I try a query like this:
>>>> where
>>>> (st_xmin(the_geom)=2365385 and st_ymin(the_geom)=5075215) and
>>>> (st_xmax(the_geom)=2366019 and st_ymax(the_geom)=5075752);
>>>> It takes ages to execute..
>>>> I take a look at the explain query it says:
>>>> "Seq Scan on polilineegb (cost=0.00..727911.08 rows=1 width=2924)"
>>>> " Filter: ((st_xmin((the_geom)::box3d) = 2365385::double precision) AND
>>>> (st_ymin((the_geom)::box3d) = 5075215::double precision) AND
>>>> (st_xmax((the_geom)::box3d) = 2366019::double precision) AND
>>>> (st_ymax((the_geom)::box3d) = 5075752::double precision))"
>>>> This is a Seq Scan, so it doesn't use the index, right?
>>>> Why?
>>>> Is there some more performing index to be used??
>>>> Thank you
>>>> Pietro
>>>> View this message in context:
>>>> http://postgis.17.n6.nabble.com/Why-postgis-doesn-t-use-index-during-query-tp5002377.html
>>>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5002378&i=1>
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5002378&i=2>
>>> If you reply to this email, your message will be added to the
>>> discussion below:
>>> http://postgis.17.n6.nabble.com/Why-postgis-doesn-t-use-index-during-query-tp5002377p5002378.html
>>> To unsubscribe from Why postgis doesn't use index during query?, click
>>> here.
>>> NAML<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> View this message in context: Re: Why postgis doesn't use index during
>> query?<http://postgis.17.n6.nabble.com/Why-postgis-doesn-t-use-index-during-query-tp5002377p5002380.html>
>> Sent from the PostGIS - User mailing list archive<http://postgis.17.n6.nabble.com/PostGIS-User-f3516033.html>at Nabble.com.
>> postgis-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130122/9927d0f4/attachment.html>
