[postgis-users] Why postgis doesn't use index during query?
Carsten Hogertz carsten.hogertz at gmail.com
Tue Jan 22 09:07:16 PST 2013
Thanks Francois,
as I am a newbie, could you please help me a bit with that idea? How should
i do? How do I calculate the X?
Thank you.
2013/1/22 Francois Hugues <hugues.francois at irstea.fr>
> Hello,
> In the with of your query, you are searching for the min distance and you
> calculate all distances between every polygons. Try add a where clause
> st_distance<  X to avoid unuseful calcul (you should find the max of the
> min to set X value). This may improve performances.
> Hugues
> Carsten Hogertz <carsten.hogertz at gmail.com> a écrit :
> I (maybe) have a similar problem.
> Could I rewrite something in my statement to make it faster?
> with dist_min as (
> select h.gid, min(st_distance(h.geom, i.geom)) dist_min from hotels_150000
> h, iata_codes i
> where h.l_iso_a2 = i.ctry
> group by h.gid
> select h.h_key, h.gid, i.loc, i.gid, d.dist_min from dist_min d,
> hotels_150000 h, iata_codes i
> where st_distance(h.geom, i.geom) = dist_min
> order by h.h_key
> thanks
> carsten
> 2013/1/22 Nicolas Ribot <nicolas.ribot at gmail.com>
> > (sorry, a little precision: All st_* predicates internally use the &&
> > GIST operator: bbox intersects)
> > On 22 January 2013 16:44, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:
> >> In PSQL, \do will list you installed operators:
> >> \do+
> >>                                 List of operators
> >>  Schema | Name | Left arg type | Right arg type |   Result type    |
> >> Description
> >>  public | &&   | geography     | geography      | boolean          |
> >>  public | &&   | geometry      | geometry       | boolean          |
> >>  public | &&   | geometry      | raster         | boolean          |
> >>  public | &&   | raster        | geometry       | boolean          |
> >>  public | &&   | raster        | raster         | boolean          |
> >>  public | &&&  | geometry      | geometry       | boolean          |
> >>  public | &<   | geometry      | geometry       | boolean          |
> >>  public | &<   | raster        | raster         | boolean          |
> >>  public | &<|  | geometry      | geometry       | boolean          |
> >>  public | &<|  | raster        | raster         | boolean          |
> >>  public | &>   | geometry      | geometry       | boolean          |
> >>  public | &>   | raster        | raster         | boolean          |
> >>  public | <    | geography     | geography      | boolean          |
> >>  public | <    | geometry      | geometry       | boolean          |
> >>  public | <#>  | geometry      | geometry       | double precision |
> >>  public | <->  | geometry      | geometry       | double precision |
> >>  public | <<   | geometry      | geometry       | boolean          |
> >>  public | <<   | raster        | raster         | boolean          |
> >>  public | <<|  | geometry      | geometry       | boolean          |
> >>  public | <<|  | raster        | raster         | boolean          |
> >> And this Pgis doc page describes them:
> >> http://postgis.net/docs/manual-2.0/reference.html#Operators
> >> All st_* predicates internally use GIST operator.
> >> Nicolas
> >> On 22 January 2013 16:39, Pietro Rossin <pierigis at gmail.com> wrote:
> >>> Is there any reference list for the GIST operators?
> >>> Thnx
> >>> Pietro
> >>> 2013/1/22 Pietro Rossin <pierigis at gmail.com>
> >>>> Superthank you!
> >>>> It works and very fast!
> >>>> Bie
> >>>> Pietro
> >>>> 2013/1/22 Nicolas Ribot-2 [via PostGIS] <[hidden email]<
> http://user/SendEmail.jtp?type=node&node=5002380&i=0>
> >>>>> Hi,
> >>>>> GIST index is only used with GIST operators:
> >>>>> &&, st_intersects, st_touches, etc.
> >>>>> You should rewrite your query to define a geographic bounding box and
> >>>>> test your data against it:
> >>>>> SELECT the_geom, layer, id
> >>>>>   FROM gauss_b.polilineegb
> >>>>>   where the_geom && 'BOX(2365385 5075215, 2366019 5075752)'::box2d;
> >>>>> Nicolas
> >>>>> On 22 January 2013 15:38, Pietro Rossin <[hidden email]<
> http://user/SendEmail.jtp?type=node&node=5002378&i=0>
> >>>>> > wrote:
> >>>>>> Hello
> >>>>>> I have a table with about 6.000.000 polilines records.
> >>>>>> The geometry value is in the_geom column.
> >>>>>> I made an index with this instruction
> >>>>>> CREATE INDEX idx_polilineegb_geom
> >>>>>>   ON gauss_b.polilineegb
> >>>>>>   USING gist
> >>>>>>   (the_geom );
> >>>>>> If I try a query like this:
> >>>>>>   where
> >>>>>>   (st_xmin(the_geom)=2365385 and st_ymin(the_geom)=5075215) and
> >>>>>> (st_xmax(the_geom)=2366019 and st_ymax(the_geom)=5075752);
> >>>>>> It takes ages to execute..
> >>>>>> I take a look at the explain query it says:
> >>>>>> "Seq Scan on polilineegb  (cost=0.00..727911.08 rows=1 width=2924)"
> >>>>>> "  Filter: ((st_xmin((the_geom)::box3d) = 2365385::double precision)
> >>>>>> AND
> >>>>>> (st_ymin((the_geom)::box3d) = 5075215::double precision) AND
> >>>>>> (st_xmax((the_geom)::box3d) = 2366019::double precision) AND
> >>>>>> (st_ymax((the_geom)::box3d) = 5075752::double precision))"
> >>>>>> This is a Seq Scan, so it doesn't use the index, right?
> >>>>>> Why?
> >>>>>> Is there some more performing index to be used??
> >>>>>> Thank you
> >>>>>> Pietro
> >>>>>> View this message in context:
> http://postgis.17.n6.nabble.com/Why-postgis-doesn-t-use-index-during-query-tp5002377.html
> >>>>>> Sent from the PostGIS - User mailing list archive at Nabble.com.
> >>>>>> _______________________________________________
> >>>>>> postgis-users mailing list
> >>>>>> [hidden email] <
> http://user/SendEmail.jtp?type=node&node=5002378&i=1>
> >>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> >>>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5002378&i=2
> >>>>>  If you reply to this email, your message will be added to the
> >>>>> discussion below:
> http://postgis.17.n6.nabble.com/Why-postgis-doesn-t-use-index-during-query-tp5002377p5002378.html
> >>>>>  To unsubscribe from Why postgis doesn't use index during query?,
> click
> >>>>> here.
> >>>>> NAML<
> http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
> >>>> View this message in context: Re: Why postgis doesn't use index during
> >>>> query?<
> http://postgis.17.n6.nabble.com/Why-postgis-doesn-t-use-index-during-query-tp5002377p5002380.html
> >>>> Sent from the PostGIS - User mailing list archive<
> http://postgis.17.n6.nabble.com/PostGIS-User-f3516033.html>at Nabble.com.
> >>>> postgis-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130122/f1a1b6e1/attachment.html>
