[postgis-users] CopyTopology cannot copy a topology that "hasz"
John Morrison
john.nmi.morrison at gmail.com
Tue Jan 22 10:24:57 PST 2013
Hi Sandro;
Thanks for the reply*!* Per your directions, please note this is the
postgis_full_version():
POSTGIS="2.1.0SVN r10775" GEOS="3.4.0dev-CAPI-1.8.0 r3737" PROJ="Rel.
4.7.1, 23 September 2009" GDAL="GDAL 1.10dev, released 2011/12/29"
LIBXML="2.7.8" TOPOLOGY RASTER
*-jm*
On Tue, Jan 22, 2013 at 1:16 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Tue, Jan 22, 2013 at 12:30:42PM -0500, John Morrison wrote:
> > Tried to copy a topology created with hasz=true via CreateTopology.
> > *temp01=# SELECT topology.CopyTopology('ma_topo', 'ma_topo_copy');
> > ERROR: Geometry has Z dimension but column does not
> > CONTEXT: SQL statement "INSERT INTO ma_topo_copy.node SELECT * FROM
> > ma_topo.node"
> > *-- $Id: topology.sql.in.c 10644 2012-11-05 10:27:08Z strk $*
> > Platform is FC17, PostGreSQL is postgresql-9.1.7-1.fc17.x86_64 (stock
> FC17
> > with updates)
> I've the impression this bug was fixed in one of the 2.0.x versions.
> Did you properly upgrade ?
> Please report output of postgis_full_version();
> --strk;
> http://www.cartodb.com - Map, analyze and build applications with your
> data
> ~~ http://strk.keybit.net
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130122/ff19bd47/attachment.html>
